1. Paultx's Avatar
    The icon is a big T letter that seems to have almost the same height of the notification bar. It has serifs and looks a bit like Times New Roman.
    I can't remember exactly if it started to appear after I took TIM as my carrier, and nothing happens if I long press on it.
    I removed the SIM card from TIM but the icon is still there. Any ideas? TIA.
    06-06-2019 04:10 PM
  2. Paultx's Avatar
    I think it began to appear after I started to have TIM as my carrier, but I'm not sure. I know for sure it wasn't there with my previous carrier. I removed the SIM card from TIM and the icon is still there.
    Nothing happens if I long press on it and I couldn't find any app it could relate to.
    Any ideas? TIA.
    06-06-2019 04:29 PM
  3. Rukbat's Avatar
    You're probably right, because that's the default place for the carrier name or logo. (You can't press things on the notification bar, they're for notifications only. If you pull it down, I don't think you'll see "Connected to the TIM network".)
    06-06-2019 05:04 PM
  4. B. Diddy's Avatar
    Which phone? Is it on the left or right side of the status bar? Do you see it in the swipedown notification panel? If so, long-press it and tap App Info.
    Show us a screenshot: http://forums.androidcentral.com/gen...d-central.html
    06-08-2019 07:02 PM
  5. B. Diddy's Avatar
    Duplicate threads merged
    06-08-2019 09:07 PM
  6. Paultx's Avatar
    It's like the screenshot I posted shows. Top left. My phone is a Moto G4 Plus.
    09-03-2019 10:58 AM
  7. B. Diddy's Avatar
    Sorry if my response seemed to ask an obvious question, but it's because I merged duplicate threads, and I think my response was in a thread that didn't have the screenshot.
    So when you swipe down the notification panel, that doesn't actually show up in there? I'd agree with Rukbat's reply above.
    09-03-2019 11:15 AM
  8. Paultx's Avatar
    I finally found the answer: that "big T" is from an app called TUFFS.
    05-07-2020 11:54 AM
  9. B. Diddy's Avatar
    Ok, glad you figured it out!
    05-07-2020 12:53 PM
  1. pixelated / freezed Android Auto with Galaxy S10+
    By oliviercmoi in forum Android Auto
    Last Post: 07-04-2019, 06:59 AM
  2. Anyone used both Samsung Buds and Airpods with S10/+?
    By torbach1 in forum Samsung Galaxy S10 & S10+
    Last Post: 06-14-2019, 11:03 AM
  3. XZ1 screen protector compatible with spigen rugged armour case.
    By Android Central Question in forum Sony Xperia XZ1 & XZ1 Compact
    Last Post: 06-06-2019, 05:47 PM
  4. Verizon Galaxy S8 New SW update removed Homescreen Icon Titles
    By roberthggl in forum Samsung Galaxy S8 & S8+
    Last Post: 06-06-2019, 07:26 AM
  5. Galaxy S10 bluetooth does not work with BMW 228i
    By chasep255 in forum Samsung Galaxy S10 & S10+
    Last Post: 06-05-2019, 09:56 PM
