1. KeepItReal's Avatar
    I have been noticing that my Moto G4 Plus had been switching to Vibrate mode or silent mode on it's own, just by leaving it idle, next to me. I have been missing calls right and left. I even performed the Factory Reset to see if that was it. I activated the System UI Tuner (pull down notification, press and hold the Gear settings symbol, then System UI appears towards end of Settings menu). I then went into the System UI Settings Tuner, under Do Not Disturb and turned off Volumes buttons shortcut (it was toggled on). So far, it had not been happening. I am hoping I have been pressing the volume down button by accident to turn there phone to Vibrate/silence. That's why I have having the buttons in the sides! My previous phones were the LG G2 & G3, buttons on the back, where I never accidently hit those buttons. I would constantly turn down my volume when I had my work Samsung Note 2.
    06-06-2017 07:48 PM
  2. KeepItReal's Avatar
    Apparently, turning this off had prevented me, or the phone, from automatically turning on vibrate only, or silent mode.
    06-09-2017 08:58 AM
  3. kbz1960's Avatar
    Glad you got it figured out
    06-09-2017 09:44 AM
  1. Gmail and Email apps not syncing
    By mrwallyy in forum Samsung Galaxy S8 & S8+
    Last Post: 11-30-2018, 03:36 PM
  2. Tethering LG G4 to non- internet connected Moto g5
    By rhohil in forum Ask a Question
    Last Post: 06-06-2017, 07:45 PM
  3. Unable to unlock galaxy j3 phone
    Last Post: 06-06-2017, 07:33 PM
  4. How do I stop the installing of the push button app
    Last Post: 06-06-2017, 07:26 PM
  5. How can i unlink phone numbers on my galaxy J5 phone
    Last Post: 06-06-2017, 07:15 PM
