When I had Android 7 nothing like this happened. Now after my Moto G4 Plus was updated to 8.1.0 I got a series of strange battery events.
If I charge the battery 100%, go to sleep and let the smartphone on, about eight hours later when I wake up the battery is at 95%, sometimes 93%–even if I let it with power saving mode on. With Android 7 it was 99% to 100% without power saving.
If I charge the battery 100%, go to sleep and let the smartphone off, when I turn it on it goes from 100% to 97% just for turning on. With Android 7 it was 100%.
When I start to use the smartphone, it goes pretty fast from 95% to 90% then 80%, and so on. Luckily, the TurboPower charger makes recharging fast, but I have to use it more times every day.
One day the battery was at 20% and zap! the phone turned off by itself. A few days later it happened at 35%!
I have a Galaxy Tab A tablet with Android 7.1.0 that behaves the same way my phone used to when it had the same OS version. That is, if I turn it on after a full charge it stays at 100% after that and stays at 100% for several minutes of use and goes at the same pace for hours.
I've tried most of the tips I found online TNA, like safe mode, checking apps, etc. Even Google Play Services, which I found could be the culprit of battery drain, I checked its version and installed a beta, also TNA. I haven't tried factory reset yet, and I don't want to unless it's the only option left.
Any ideas how I can fix that? TIA.
