1. AC Question's Avatar
    Its so annoying to find out you have been called but phone did not ring. It has happened many times now, Please send us remedy.
    05-17-2017 12:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! This can happen if your cell signal was poor when the call came in. Check your cell signal strength in the Settings>Battery​ menu (it usually shows up if you tap the battery graph to expand it). Or you can use GSam Battery Monitor.
    05-17-2017 04:22 PM
  1. s7 is playing deleted movie
    Last Post: 05-20-2017, 05:29 PM
  2. using the zoom on galaxy s8
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-17-2017, 09:11 PM
  3. Verizon Galaxy S8 Changed to a Galaxy S8 Plus from Iphone. Now my photos won't load to certain apps. Any idea why?
    By Suzette0796 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-17-2017, 07:51 PM
  4. Missing Text Notification on Lock Screen and Status bar on Galaxy 7edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-17-2017, 12:28 PM
  5. Replies: 0
    Last Post: 05-17-2017, 12:24 PM
