1. bking1901's Avatar
    Last night I installed nova launcher, and some other applications to get the pixel 2 look. I charged up to 100% then unplugged and went to sleep, and woke up ~7 hours later to find it at 90%. This isn't a major drain, but it usually would only go down to around 96%. I then have been using it a little bit this morning for about an hour, and it's now down to 82%.
    This is clearly faster than usual for me, and my question is if nova or another app I installed can be causing this. These are the apps I installed:
    nova launcher
    just another widget
    pixel 2 icon pack
    Here's the breakdown from the battery page in settings:
    cell standby 6%
    phone idle 3%
    screen 3%
    android os 2%
    android system 1%
    2 apps 1% each
    Thanks all
    11-08-2017 09:07 AM
  2. Tim1954's Avatar
    You can go into the app settings and you will get a what battery the launcher used since last charge...
    11-08-2017 09:24 AM
  3. Rinsun's Avatar
    I have Nova Prime(stable version) installed on my Moto G5 Plus with Pixel Icon pack (Saurabh Gupta) and Dives icon pack. I use Chronus clock and Weather widget. if I charge my phone to 100% before going to bed it is usually 96 - 98 % when I wake up.
    Like Tim1954 said,you can check in Settings > Apps for battery usage of each of these apps you installed .
    11-08-2017 11:04 AM
  4. Javier P's Avatar
    Also, tap on the battery graph and see the signal bar, just in case you are getting a weak cellular signal.
    Rinsun likes this.
    11-08-2017 11:21 AM
  5. Hemicrusher's Avatar
    Using Nova Prime Beta and went to bed with 100% and woke to 97%....7 hours. Only widget I use is Chronus Clock. Been on the phone since and it is at 93%
    11-15-2017 10:01 AM
  1. Samsung S8 pop up after call ended
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 11-13-2017, 10:41 AM
  2. Clearing Cache Daily v Battery Drain?
    By Stwutter in forum Android 7.0 Nougat
    Last Post: 11-09-2017, 12:34 AM
  3. Replies: 2
    Last Post: 11-08-2017, 02:22 PM
  4. Replies: 1
    Last Post: 11-08-2017, 08:38 AM
  5. Samsung S8 pop up after call ended
    Last Post: 11-08-2017, 02:20 AM
