    I've just upgraded from a 2014 Moto G to a G5 Plus. On the G there was a tiny white LED that slowly pulsated to alert you of notifications. I don't see this on the G5+. Is there one, or is there a setting to activate it?
    Geeksatee likes this.
    01-28-2018 04:55 AM
  2. Rinsun's Avatar
    There is a hidden LED which blinks when I power on my phone but it doesn't provide an alert for notifications. I don't think you can activate it without root access.
    01-28-2018 08:02 AM
  3. Geeksatee's Avatar
    Moto G5 Plus has a hidden LED indicator, which is located at the earpiece speaker. But Motorola has disabled its function as a notification indicator. This LED works when the time of battery completely dead as well as the time of charging. If you are ready to root the phone, then you can use the LED as a notification indicator, but it is risky, because you may lose your warranty on the phone.
    Rinsun likes this.
    01-28-2018 09:16 AM
  4. acejavelin's Avatar
    Be aware that even if you root the device, this LED only functions when when you are connected to external power (USB or adapter) because it is hard wired into the charging circuit. Honestly, this LED is useless.
    01-29-2018 12:47 PM
  5. Macdtek's Avatar
    is there a decent app that can be used or an apk file?
    01-30-2018 07:27 AM
  1. I don't have the account last synced to my phone
    Last Post: 01-28-2018, 05:44 AM
  2. Why does my battery take so long to charge??
    Last Post: 01-28-2018, 05:35 AM
  3. Email notification badge
    By Phoebian in forum Huawei P10 & P10 Plus
    Last Post: 01-28-2018, 05:19 AM
  4. i have a le pan tablet
    Last Post: 01-28-2018, 03:11 AM
  5. Note 3: Rest to Factory-Backup Apps wont restore as says not the same phone
    By Note3 Phone User in forum Samsung Galaxy Note 3
    Last Post: 01-28-2018, 01:20 AM
