1. varamilianc's Avatar
    Will a charging port flap cover on a Motorola G7 Play case damage the device while it's charging? I have a Poetic case for my Motorola G7 Play and it has a charging port cover/flap that covers the port. When I plug the charger in the flap sort of pushed against the charging connector, will this at all damage the charging port?
    10-18-2019 06:43 PM
  2. B. Diddy's Avatar
    Most likely not. It would depend on how much pressure it's exerting on the plug, but my guess is that the pressure is minimal
    Laura Knotek likes this.
    10-19-2019 01:01 AM
  3. Rukbat's Avatar
    I've been using Otterbox Defenders for years, they push pretty hard against the connector. But if you're careful, and keep the flap away from the connector until it's fully seated, you shouldn't have any problem. (Trying to plug it in on an angle because the flap is in the way could cause damage.)
    10-20-2019 04:10 PM
  1. Google is afraid of Samsung, which is why the Pixel 4 is lackluster.
    By SupraLB in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 11-03-2019, 06:32 AM
  2. How does the back hold up caseless?
    By ImTurningViolet in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-20-2019, 08:33 AM
  3. Accessing filesystem on old Android ZTE N800
    By TBXYZ in forum Android Security Talk
    Last Post: 10-19-2019, 01:02 AM
  4. Warranty Repair And Replacement In The U.S.
    By Climb14er in forum OnePlus 7T & OnePlus 7T Pro
    Last Post: 10-18-2019, 06:53 PM
  5. Linux on Dex is dead
    By bill-e in forum Samsung DeX
    Last Post: 10-18-2019, 05:02 PM
