1. heath patrick's Avatar
    Can anyone confirm if Wi-Fi calling works on Verizon with an unlocked G7 power?
    05-13-2019 07:45 PM
  2. 1901Madison's Avatar
    I'm fairly certain the answer is that no, WiFi calling does not work on an unlocked G7 Power.
    05-14-2019 10:49 PM
  3. lgbalfa's Avatar
    Does that mean I cannot have WiFi calling on my G7 Power purchased directly from Verizon?
    Thanks
    06-05-2019 10:54 PM
  4. Mike Dee's Avatar
    Thanks
    If it's a Verizon model it's not an issue.
    06-05-2019 10:58 PM
  5. lgbalfa's Avatar
    Thanks.
    Do you know where the setting is for this?
    06-05-2019 11:16 PM
  6. lgbalfa's Avatar
    I was able to find it.
    06-05-2019 11:24 PM
  7. 1901Madison's Avatar
    Could I flash Verizon firmware onto the unlocked model and get WiFi calling?
    06-06-2019 06:59 AM
  8. Mike Dee's Avatar
    The Verizon firmware would support it
    06-09-2019 10:40 AM
  9. mustang7757's Avatar
    If you go from a Verizon firmware to unlocked it might or might not support wifi calling , I know tmobile still works , att gave me errors , but on Verizon to unlocked you'll lose RCS or any carrier enhancements.
    06-09-2019 10:46 AM
  10. 1901Madison's Avatar
    I'm asking about the opposite. I bought unlocked from Best Buy. I'm curious if I could flash the Verizon firmware in order to get WiFi calling.
    06-09-2019 02:51 PM
  11. mustang7757's Avatar
    Oh yes definitely then , you'll be on Verizon version.
    06-09-2019 05:52 PM
  12. 1901Madison's Avatar
    Do you know where I could find the Verizon firmware?
    06-10-2019 06:27 PM
  13. mustang7757's Avatar
    Sam mobile, XDA forum
    06-10-2019 06:46 PM
  1. Wi-Fi calling ongoing notification verizon
    By wolfkiel33 in forum Samsung Galaxy Note 8
    Last Post: 05-14-2019, 04:33 AM
  2. no mic symbol on any keyboard Alcatel ?
    Last Post: 05-14-2019, 03:38 AM
  3. How to permanently disable internet (wifi & data) on android? (sony x compact)
    Last Post: 05-14-2019, 12:34 AM
  4. How do I replace the screen on my Alcatel 7 6062w?
    By Sami Simmons in forum Ask a Question
    Last Post: 05-13-2019, 07:10 PM
  5. Replies: 0
    Last Post: 05-13-2019, 05:20 PM
