    I just recently got the Moto G7 Power which has much more stock android than I am used to, having come from using 3 straight Samsung phones.
    On Samsung you can type in the PIN and it will auto-unlock. With stock/Motorola, I have to type in the PIN and then press enter/check/confirm.
    Not a huge time waster, but if it's possible to get rid of that extra button in any way I'd love to hear about it!
    05-30-2019 03:11 PM
  2. SpookDroid's Avatar
    No way to do that other than to use a Custom ROM that doesn't have that (and has replaced the lockscreen with something different).
    05-31-2019 09:04 AM
  3. Scott337's Avatar
    You could use a Pattern instead of PIN. I use a Pattern unlock and no extra buttons to push (Moto Z2 Force, Z2 Play and Droid Turbo). Just a thought.
    SpookDroid likes this.
    05-31-2019 09:21 AM
  1. Microsoft Office Calendar Appointments Won't Sync With S9+ and Vice Versa
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-05-2019, 10:07 AM
  2. Replies: 1
    Last Post: 06-03-2019, 01:46 PM
  3. need to hard reset a kospet optimus pro watch without settings option
    By Android Central Question in forum Smartwatches (Non Android Wear / Wear OS)
    Last Post: 06-01-2019, 03:28 PM
  4. Microsoft Office Calendar Appointments Won't Sync With S9+ and Vice Versa
    Last Post: 05-30-2019, 11:41 AM
  5. Uploading videos to Fb messenger with Samsung 10+
    Last Post: 05-30-2019, 06:01 AM
