10-02-2019 11:16 PM
52 123
tools
  1. lgbalfa's Avatar
    Every few days, even though I delete / remove "Duo" from my accounts on this phone, it keeps re-appearing.
    I don't want it on my phone and it is very annoying that it keeps coming back.
    How do I get rid of it completely?
    Thanks
    06-16-2019 09:52 PM
  2. B. Diddy's Avatar
    Was Duo preinstalled on the phone? If so, can you Disable it in Settings>Apps​?
    06-17-2019 04:17 PM
  3. lgbalfa's Avatar
    Yes - preinstalled.
    Every time I go to "remove account" it always comes back.
    It is even listed in "Disabled apps" but keeps coming back.
    Removing Duo account on G7 Power, but still keeps re-appearing-0-02-01-9f5849ec9d3eaed48a52c0b043dc97dde29db572e8238c89204fd052687092d0_442e82e0.jpg
    06-17-2019 09:05 PM
  4. B. Diddy's Avatar
    If you don't use Duo at all, have you tried deleting your Duo account (in the Duo app's settings)?
    06-18-2019 03:24 PM
  5. mustang7757's Avatar
    What is weird is that I never even had a Duo account set-up so what I just did was set one up and then I just deleted it.
    As you can see from my previous post, I disabled it but it still keeps coming back.
    Attachment 304524
    I would recommend you block your number and repost the screenshot
    06-18-2019 11:43 PM
  6. lgbalfa's Avatar
    How do you block your number?
    06-18-2019 11:44 PM
  7. mustang7757's Avatar
    Erase your current picture and edit it through your gallery by blacking it out with editing tools there
    06-18-2019 11:47 PM
  8. Laura Knotek's Avatar
    I've edited the screenshot to remove the personal information.
    mustang7757 likes this.
    06-18-2019 11:54 PM
  9. mustang7757's Avatar
    Thank you
    Laura Knotek likes this.
    06-18-2019 11:54 PM
  10. Laura Knotek's Avatar
    Thank you
    You're welcome. Thanks for noticing that.
    06-18-2019 11:55 PM
  11. lgbalfa's Avatar
    Sorry if this seems like a simple question but where do you remove your current picture from?
    06-18-2019 11:57 PM
  12. B. Diddy's Avatar
    I still see the phone number.
    06-19-2019 12:15 AM
  13. mustang7757's Avatar
    Which are you using forum app or AC app?
    06-19-2019 12:20 AM
  14. mustang7757's Avatar
    Yeah there's one more
    06-19-2019 12:20 AM
  15. lgbalfa's Avatar
    What do you mean?
    You said I should remove the photo?
    I thought you meant on my phone?
    06-19-2019 12:22 AM
  16. mustang7757's Avatar
    What do you mean?
    Here in the forums I meant
    06-19-2019 12:23 AM
  17. lgbalfa's Avatar
    OK, which photo am I removing and how will that fix the issue of DUO always reappearing?
    06-19-2019 12:24 AM
  18. mustang7757's Avatar
    It's to remove your phone number ,not fix Google duo.
    06-19-2019 12:25 AM
  19. lgbalfa's Avatar
    OK, I deleted the message showing the phone #.
    Hoping someone has a fix regarding DUO.
    06-19-2019 12:29 AM
  20. mustang7757's Avatar
    Ok cool
    I'm going check my Google phone , see if j can see anything there as it close to your Moto phone
    06-19-2019 12:31 AM
  21. lgbalfa's Avatar
    Ok cool
    thanks
    06-19-2019 12:35 AM
  22. mustang7757's Avatar
    thanks
    Ok when I go into my duo app , in settings of the app 3 Dots right corner you can delete the account there and also sign out and remove Google account from duo
    06-19-2019 12:37 AM
  23. mustang7757's Avatar
    You can also uninstall the app ?
    06-19-2019 12:40 AM
  24. lgbalfa's Avatar
    How do you permanently uninstall the app?
    Thanks
    09-29-2019 09:47 PM
  25. mustang7757's Avatar
    Thanks
    When you long press it and tap info is there a option to uninstall it?
    09-29-2019 09:51 PM
52 123
  1. You tube on kara close aahe
    Last Post: 06-17-2019, 04:21 PM
  2. How to get out of Fastboot mode on Lg G& thinq?
    By Android Central Question in forum LG G7 ThinQ
    Last Post: 06-17-2019, 03:15 AM
  3. Where is Calculator app on s9 location
    Last Post: 06-16-2019, 09:22 PM
  4. Changing fonts on Pixel
    By krishnansasikumar in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 06-16-2019, 01:57 PM
  5. My phone (Samsung J7) is always on vertical
    Last Post: 06-16-2019, 01:32 PM
