Removing Duo account on G7 Power, but still keeps re-appearing
lgbalfa
599
33
28
Every few days, even though I delete / remove "Duo" from my accounts on this phone, it keeps re-appearing.
I don't want it on my phone and it is very annoying that it keeps coming back.
How do I get rid of it completely?
Thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
Re: Removing "Duo" account on G7 Power, but still keeps re-appearing
Was Duo preinstalled on the phone? If so, can you Disable it in Settings>Apps​?
lgbalfa
599
33
28
Yes - preinstalled.
Every time I go to "remove account" it always comes back.
It is even listed in "Disabled apps" but keeps coming back.
0-02-01-9f5849ec9d3eaed48a52c0b043dc97dde29db572e8238c89204fd052687092d0_442e82e0.jpg
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
If you don't use Duo at all, have you tried deleting your Duo account (in the Duo app's settings)?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,565
6,152
113
What is weird is that I never even had a Duo account set-up so what I just did was set one up and then I just deleted it.
As you can see from my previous post, I disabled it but it still keeps coming back.
I would recommend you block your number and repost the screenshot
lgbalfa
599
33
28
Sorry if this seems like a simple question but where do you remove your current picture from?
lgbalfa
599
33
28
OK, which photo am I removing and how will that fix the issue of DUO always reappearing?
lgbalfa
599
33
28
OK, I deleted the message showing the phone #.
Hoping someone has a fix regarding DUO.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,565
6,152
113
Ok cool
I'm going check my Google phone , see if j can see anything there as it close to your Moto phone
steve1084
