1. dfbaskwill's Avatar
    The first light on the battery now stays on all the time after charging. The battery gradually drains without use because of this. What to do?
    01-09-2018 07:35 PM
  2. YAYTech's Avatar
    May need to know which brand/model, but I won't personally know what to tell you with any of them. Sounds like some kind of error. Have you let it drain completely to see if it might reset itself?
    01-10-2018 05:47 PM
  3. dfbaskwill's Avatar
    It's the Turbo Battery Pack. Really acting weird. I might as well completely drain it and see.
    01-10-2018 08:48 PM
  4. turbochgd's Avatar
    I've also noticed some anomalies with the lights. Don't have your issue, but do notice them (not sure if it's one or more of the lights) flashing periodically at night time. So it must be happening constantly but that's the only time I can see it.
    01-12-2018 02:20 AM
  5. dfbaskwill's Avatar
    Took it back to Verizon. They hadn't heard of any issues but cheerfully swapped it out for another one even though I didn't ask for it. No problem with the new battery.
    turbochgd likes this.
    01-12-2018 08:13 AM
  1. Samsung/Android speaker problem
    Last Post: 01-09-2018, 04:38 PM
  2. Notification problem.
    Last Post: 01-09-2018, 12:07 PM
  3. Replies: 1
    Last Post: 01-09-2018, 11:49 AM
  4. How do I solve this weird crashing problem?
    By Atila Belloquim in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-09-2018, 11:47 AM
  5. Replies: 0
    Last Post: 01-09-2018, 08:28 AM
