1. slave's Avatar
    okay, this is my first rodeo with stock (nearly stock) Android.
    On my Galaxy phones and wife's Evo's, and my Palm Pre, you need to type just the first few letters of a name to get a contact.
    For instance, if I want to call Damon, I simply dial 326, then a list comes up, it contains all of my contacts whose first three letters of the name coincides with those numbers (T9). Damon is usually first.
    It will also have area code 326 numbers at the bottom of the list (I have no 326 area code firends).
    It seems I can not do this on the Moto X, and I assume all stock Android.
    Or, can I? Is there a way to enable this feature?
    08-31-2013 09:23 PM
  2. tippmann15's Avatar
    I just hit the "settings" button while the dial pad was open, I enabled exactly what you're referring to (it didn't come default). I didn't notice it wasn't enabled, but glad it is now.
    08-31-2013 09:26 PM
  3. slave's Avatar
    What setting did you hit? I tried that.
    08-31-2013 09:31 PM
  4. jameskk1's Avatar
    Do you have the VZW model? Because I'm not seeing on the phone/settings menu on my at&t phone
    08-31-2013 09:34 PM
  5. slave's Avatar
    I have the AT&T, there is a settings button, bottom right, but I can't find a setting that enables this.
    08-31-2013 09:40 PM
  6. still1's Avatar
    That feature is on stock android 4.3 dialer app. I have it on my Nexus 4
    I believe Moto X uses stock dialer so you might get it in a month or so but its not there now.
    08-31-2013 11:32 PM
  7. slave's Avatar
    Ah, so it is a TW/Sense/WebOS faeture but not stock Android until 4.3..... good to know.
    09-01-2013 12:03 AM
  8. jameskk1's Avatar
    BTW - I've also got the Verizon Droid Maxx (the new Droid) and it does allow you to look up names by dialing them... so I am thinking the poster might have the VZW version of the X since it seems to have some of the same features/software as their new Droid line
    09-01-2013 12:33 AM
  9. PokerMunkee's Avatar
    Is there not a way to do this with the VZW Moto X? I don't see anything in the Call Settings to enable this. Can't believe this isn't stock on Android.
    10-05-2013 06:30 PM
  10. davidnc's Avatar
    I dont see a setting to make this happen currently on vzw Moto X.Maybe with the next update as mentioned above ?Or install a 3rd party app til then?
    I will probaby wait and see if the stock dialer gets that feature tho.
    10-05-2013 07:12 PM
  11. anthony2558's Avatar
    It used to be stock but I believe it was a patent suit with Apple that ended it on stock android versions. Just like the search your entire phone via the simple search icon. Now you have to use the magnify glass in the call screen.
    T-mobile Moto X
    10-05-2013 07:16 PM
  12. Tom in Bristol's Avatar
    Try this...on the dial pad screen touch the Search magnifying glass (bottom left) then type in the first few letters of a contact name OR type the first few numbers of a contact...should get a listing of all that fit.
    10-05-2013 07:19 PM
  13. PokerMunkee's Avatar
    That's not too bad, just one more click. I suppose that will work for now. Thanks.
    10-05-2013 10:33 PM
  1. Replies: 12
    Last Post: 02-18-2016, 03:40 PM
  2. Replies: 13
    Last Post: 10-03-2013, 09:26 AM
  3. Samsung Replenish phone taking pictures that are inverted
    By cmartin1500 in forum Samsung Replenish
    Last Post: 09-01-2013, 08:20 PM
  4. Does battery defender do any to help battery life?
    By worldsoutro in forum Motorola Droid MAXX
    Last Post: 08-31-2013, 09:18 PM
