1. hobojoe196061's Avatar
    So I was wondering if the low power cores for sensors and notifications run based on the hardware (sensors being used) or do they require specific APIs? The reason I ask is because if these run based on the sensor use, the majority of "battery draining apps" should be extremely efficient on the Moto X. In theory the fitness apps like Moves should be able to be run in background with little hit on battery life.
    11-02-2013 01:12 AM
  1. Converting into GPE questions
    By SC1 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 11-11-2013, 06:12 PM
  2. Two quick questions for you watch pro's!
    By Gsxr151 in forum Samsung Galaxy Gear
    Last Post: 11-04-2013, 07:27 PM
  3. Assist Question - Can you set a default music app?
    By phathands in forum Motorola Droid MAXX
    Last Post: 11-04-2013, 12:33 PM
  4. Change power menu and tiles
    By DanielAnton in forum Android 4.4 KitKat
    Last Post: 11-02-2013, 06:31 PM
  5. New member here with a question...
    By jyi615 in forum Samsung Galaxy Note 3
    Last Post: 11-01-2013, 12:32 PM
