1. caseyatc's Avatar
    I searched and didn't didn't find the answer. When my X is charging the battery % shows up on the screen when I push the power button.
    Is there a way to put that on the power on screen when phone isn't charging?
    12-02-2013 10:00 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    So you want the battery percentage on the lockscreen at all times? You can download Dashclock widget. That is what I have on my X.
    12-02-2013 10:09 AM
  3. caseyatc's Avatar
    Thanks, I downloaded dashclock with the battery extension, now I have to figure out how to get it onto the lock screen and not a home screen. This is pretty much what I was looking for.
    12-02-2013 10:50 AM
  4. Golfdriver97's Avatar
    So you want similar to what I have?
    From a Sprint Moto X using AC Forums app
    12-02-2013 10:59 AM
  5. caseyatc's Avatar
    yep. so when I power on i can see battery % before i slide to unlock.
    12-02-2013 11:01 AM
  6. caseyatc's Avatar
    Got it. Figured it out, I'll chalk this up to todays "learn something new every day"
    Thanks again
    grooks likes this.
    12-02-2013 11:21 AM
  7. Golfdriver97's Avatar
    Glad you got it sorted. Sorry about taking so long to reply.
    See you around the forums.
    12-02-2013 11:53 AM
  8. howdydoesit's Avatar
    Any way to get it to default to the widget? Every time I open my phone it shows the default unlock screen.
    *Edit: Figured it out, I should've read the instructions first. Just drag the widget to the right...pretty simple.
    Sent from my XT1060 using Tapatalk
    12-03-2013 02:16 AM
  9. str8bucs's Avatar
    Can you still have this with pin code lock?
    12-03-2013 08:46 AM
  10. Golfdriver97's Avatar
    If you mean Dashclock, yes.
    12-03-2013 09:37 AM
  1. Broken Screen question
    By John-Smith in forum Google Nexus 4
    Last Post: 12-09-2013, 10:10 PM
  2. How do i back up my files with a broken screen
    By marab123 in forum Samsung Galaxy Note 2
    Last Post: 12-06-2013, 02:40 PM
  3. Mugen 6500mah Extended Battery
    By Man In Black 805 in forum Samsung Galaxy Note 3
    Last Post: 12-03-2013, 04:40 AM
  4. Network signal grey bars when wifi on
    By Lugz6002 in forum Moto G (2013)
    Last Post: 12-02-2013, 11:17 AM
  5. Verizon Samsung Galaxy Note II $50 with $200 gift card on contract
    By dpham00 in forum Verizon Galaxy Note 2
    Last Post: 12-02-2013, 09:07 AM
