Hi all, just wanted to get some opinions on my situation......I have a moto x for a few weeks, updated to kit kat. While I'm not experiencing drastic idle battery drain like some people, I am experiencing something strange. I have a stock moto x, no 3rd party apps installed at all. I don't use the phone much, manually check email a few times a day, surf the web maybe half hour a day.
I have everything optional turned off...wifi, bluetooth, auto synching off, data off, Motorola Assist off, location services off (unchecked), GPS off. The only thing I have activated is active display. The phone basically can just be used for calls and texts.
What I'm finding is with this setting I get great stand by time at night...from 7PM to 7AM (span of 12 hours), I will only lose about 4% battery...which is awesome! However, from about 9AM-6PM, (span of about 9 hours), I will lose about 12% with the phone on the same settings. Signal reception is great both at night and during the day. Android OS is taking the most battery % ~25-30%. I've had other cell phones (Sony) using gingerbread and ice cream sandwich which never had Android OS in the battery stats ever! Phone idle and Cell Standby would be at the top of battery usage normally, but with the Moto x it's Android OS. And I'm using this phone exactly the same as my previous phones...no change in behavior. Again, I know it's not crazy idle battery drain like some have, but was just curious as to what might be using more battery during the day than at night.
Will Gsam battery monitor help figure this out? Does the app breakdown what Android OS usage is? I'm just super curious as to what it could be. Thanks!
