A
AC Question
Moto X (2013) - Major Problems After Lollipop Update
I received an android update notification on my Moto X last week for lollipop (I think version 5.1) and I have had problems ever since.
At first it seemed work fine after the update installed but then I noticed that I could not send texts via handcent (receive texts only). Also the stock email app would only display a blank white screen. I then got an error with some apps saying it could not load because Google Play Services (GPS) was not up to date. I tried to download GPS and it stopped downloading when it reached 57%. I tried to clear GPS cache and then I tried to uninstall GPS in order to reinstall it. Then a handcent text pop-up came in and I could not "x-out" the pop-up. That's when things really started to get buggy.
Now when the phone is booted the initial Moto X animated screen is visible but then it goes into a black screen and the login screen never appears. If I let it sit for a few minutes it will occasionally display the time or a notification (voice message icon, etc) but swiping down does not unlock the phone. It just does a short vibrate and then goes black. Also the battery gets hot when it is left on (while the screen is black). Plugging the phone into the computer is not recognized as an external drive (probably because it doesn't boot properly). I tried booting in fastboot mode, recovery, then to wipe the partition cache (twice already) and it still does not properly boot.
My first priority is to be able to access the internal memory to recover data that has not been backup up yet. Is it possible to do this before trying a factory reset? Is there a way to access the internal storage in fastboot mode or some other way?
If the only option is a factory reset is there a way I try to recover data after a reset (data recovery tools, etc)? I don't mind doing a factory reset...just want to be able to access the data.
Any help would be appreciated!
