1. Camilo's Avatar
    I have a 2013 Moto X Android Version 5.1 ATT network.
    I have been using this phone to play audio via Bluetooth through my 2013 Subaru Impreza. It connects automatically and all the controls work fine.
    The audio quality suddenly changed yesterday. I get a quiet "click" sound every second (timed it - 60 clicks in a minute). Also, more or less randomly, it emits a very loud, harsh rasping/static type sound, sometimes momentarily, sometimes it continues and I have to turn off the sound system or switch the mode to FM, etc. This sound is very loud (regardless of the volume setting on the sound system). So loud it seems like it would damage the speakers. When I go back to Bluetooth, the harsh sound is gone but the click remains. I'm not sure, but I think the click varies in loudness from barely audible to noticeable. This doesn't seem to relate to the volume of the sound system.
    This wasn't the case a couple of days ago - no clicking, none of that loud sound. Just seemed to happen out of the blue. I haven't done anything (that I can think of) to the phone. The audio files I'm playing are the same ones that I was playing before without problems.
    I've tried it with and without the phone enabled (i.e. media only) and with and without the wifi turned on. No difference.
    I've tried various positions with the phone ranging from my pocket or briefcase to nearby the audio head. No difference.
    I've tried unpairing and re-pairing the phone and also deleting the connection from the phone and re-establishing it. I've also tried clearing the cache before re-pairing.
    These sounds don't happen when using the radio.
    I've also tried it with another smart phone I have - and old Samsung that I have - and the audio is clear, without any clicking etc. So I don't think it's a Subaru issue, but something going on with my phone.
    Again, this is a change that just seemed to happen spontaneously from one day to the next.
    Can anyone give me some advice about what might be going on and/or a forum on bluetooth that I might go to to figure this out?
    Thanks in advance
    09-03-2015 12:41 AM
  2. firepsych's Avatar
    Try a different BT device with this phone?
    Sent from my XT1060 using Tapatalk
    09-03-2015 05:48 AM
  3. Camilo's Avatar
    Thanks. As I was sitting in my driveway with the car running trying all the above options, I didn't think of that even though my wife's car was right there. That's the only other BT device we have. I'll give that a try.
    That made me think of another thing I didn't try - running the BT audio from the phone with the car on, but not running. I'll try that too.
    In the mean time, if anyone has any advice or pointers to other sites, I'm all ears!
    09-03-2015 11:14 AM
  4. javyn's Avatar
    I have this problem as well with SYNC in my Ford Fusion. Either the audio over BT is very glitchy, or the audio comes out of my phone even though it says Bluetooth is successfully connected.
    This happens with all BT audio devices, car, headphones, you name it.
    Yet another problem to add to the litany since I've gotten this phone.
    09-04-2015 04:37 PM
  5. Camilo's Avatar
    For what it's worth, now the Phone and Subaru BT are working perfectly together again. No clicking, no random loud sounds. Next time it happens (if ever), I'll try the phone with a different car BT... which I didn't do this time because by the time I was going to try it, the problem had resolved.
    09-07-2015 05:45 PM
  6. firepsych's Avatar
    Solved my problem.
    Found this on another forum and didn't copy the link. Sorry.
    But it suggested I change my devices name in Bluetooth settings and then using the Voice Commands only through the steering wheel, delete my device from my car and then re-pair it using Voice Commands only through the steering wheel.
    My Moto X now pairs automatically if it's already on when I get in the car.
    For me at least, this method survives reboots.
    Did you get your phone to connect automatically again? Mine connects, but I have to do it manually.
    2013 VZW Moto X 5.1. Stock, locked, unrooted.
    2013 Subaru Outback Premium
    Sent from my XT 1060 using Tapatalk
    09-21-2015 04:48 PM
  7. javyn's Avatar
    Still had problems with this, ended up ditching the phone.
    12-29-2015 11:19 AM
  1. Why doesn't android auto connect to car navigation?
    By Sonata2015 in forum Android Auto
    Last Post: 09-23-2015, 11:08 AM
  2. Does the Moto 360 support the Samsung Note 5?
    By Logan Enright in forum Moto 360
    Last Post: 09-04-2015, 10:49 PM
  3. Are we getting our own Moto X Pure Forum?
    By ndonnine in forum Moto X Pure Edition
    Last Post: 09-03-2015, 10:41 AM
  4. Replies: 0
    Last Post: 09-03-2015, 12:19 AM
  5. Can I get some help with a Galaxy S3 connection problem?
    By makaylaleigh in forum General Help and How To
    Last Post: 09-02-2015, 10:41 PM
