1. Vapor916's Avatar
    Any solution? Do I need to update to Lollipop? SMS works though.
    09-21-2015 10:10 PM
  2. Vapor916's Avatar
    bump
    09-23-2015 02:08 AM
  3. wplust's Avatar
    Are you trying to send MMS without turning on your cellular data? I know that this used to work on KITKAT, but apparently it doesn't on Lollipop because it doesn't allow the apps to turn on cellular data.
    Sent from my XT1060 Moto X DE
    09-23-2015 12:27 PM
  1. Can I use an unlocked T-mobile Samsung Galaxy s6 edge on AT&T's network?
    By hawkeye138 in forum Samsung Galaxy S6 edge
    Last Post: 09-24-2015, 01:41 PM
  2. Noise when opening camera
    By spydersilk in forum Samsung Galaxy S6 edge+
    Last Post: 09-22-2015, 11:24 AM
  3. Galaxy S5 SLOW when using WiFi
    By Ryan K2 in forum General Help and How To
    Last Post: 09-21-2015, 10:02 PM
  4. Error: Error loading player: No playable sources found
    Last Post: 09-21-2015, 09:22 PM
  5. Why won't Burner App start on galaxy Core prime?
    Last Post: 09-21-2015, 09:20 PM
