1. Petros DIMITRIOU's Avatar
    Being extremely happy with my X 2014, there was one thing missing
    Battery autonomy
    Decided to try the X Play, considering its very very big battery capacity
    I am now using the X Play with the Sim in, while I have the X 2014 without a Sim card just at my desk.
    Both phones have been out of a charger for the last 36 hrs.
    The X 2014 has 42% of battery left, with no air time and only 8 minutes of SOT. Its available RAM is at 816 MB.
    The X play has 41% of battery left, with 60 mins calls and 2.5 hrs of SOT. Its available RAM is surprisingly enough at 973 MB
    The battery difference is very clear between the phones, with the X Play being absolute king here. What I find intruiging is the memory difference, considering both phone have exactly the same apps installed. It seems that again, X Play manages its RAM better than its "father" the X 2014...
    Attached Thumbnails Battery and memory difference between X Play and X 2014-screenshot_2015-10-22-20-07-07.jpg   Battery and memory difference between X Play and X 2014-screenshot_2015-10-22-20-07-14.jpg
    10-22-2015 02:13 PM
  2. dao hong's Avatar
    Sorry but, What is Xplay? If it is a softwave, pls give me a link
    10-26-2015 03:17 AM
  3. dao hong's Avatar
    Oh no. I was careless when clik the link through SIMILAR THREADS from battery of S6 Egde, sorry
    10-26-2015 03:22 AM
  4. girinath's Avatar
    Which has a better display? Can you tell me the difference in call quality, speakers too... Want to know which one is better..
    Posted via moto x play
    10-27-2015 02:50 AM
  5. Petros DIMITRIOU's Avatar
    Display, eh?
    OK.
    Moto X Play (pluses)
    Bigger screen
    Brighter, very very brighter screen, easy to see even under direct sunlight
    Moto X 2014 (pluses)
    Truer color reproduction
    AMOLED technology means notifications do not light up the whole screen
    10-27-2015 05:31 PM
  6. girinath's Avatar
    Can you tell me more comparison between these two phones I.e. performance, battery, OS. Upgradable or not to M etc...
    I have the play and my friend is gonna buy the moto x 2014 so would like to know.
    Thanks
    10-29-2015 09:35 AM
  7. Petros DIMITRIOU's Avatar
    OK.
    Battery. Moto X Play is the ABSOLUTE King. I charge it every second day, while the Moto X 2014, I needed to charge every single day, even midday depending on its use. The Moto X Play is amazing in the battery department, and my best pure or almost pure android phone EVER.
    Performance. Moto X 2014 operates very very smoothly. Stutters and lags are a very very rare occurence on this phone. Very happy with it. The Moto X play suffers from stutters and lags. Am I happy with it? No. Is it something that bothers me so much that I cannot stand the phone? Hell no. It is slightly bothersome, but the fact is that all apps operate without a problem, even when multiple apps are open simultaneously. The stuttering occurs, when sliding an app to the side and is immediately visible.
    OS. Moto X 2014 runs on 5.1, Moto X Play runs on 5.1.1. Both will receive an upgrade to M. When? Only God and Motorola knows
    All in all, for my usage and needs the Moto X Play wins hands down. Very big, very bright screen, excellent battery autonomy, these are the things I was actually missing from my X 2014. And I have found them at the Moto X Play. It is NOT a flagship phone, it is a very very good middle class phone, and I love it
    10-30-2015 12:09 PM
  1. Replies: 0
    Last Post: 10-22-2015, 01:45 PM
  2. Replies: 0
    Last Post: 10-22-2015, 01:34 PM
  3. S planner link two different accounts
    By Yogit in forum Ask a Question
    Last Post: 10-22-2015, 12:40 PM
  4. Replies: 0
    Last Post: 10-22-2015, 12:20 PM
  5. Replies: 0
