1. Jake12121's Avatar
    When I first got this phone (about two weeks ago) I was going days without charging it. It now drops almost instantly. Please help :/
    02-13-2016 11:03 PM
  2. B. Diddy's Avatar
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    Laura Knotek likes this.
    02-14-2016 12:10 AM
  3. Jake12121's Avatar
    So I have some screenshots and it just doesn't look right.
    02-14-2016 05:09 PM
  4. Jake12121's Avatar
    02-14-2016 05:10 PM
  5. Jake12121's Avatar
    02-14-2016 05:10 PM
  6. Jake12121's Avatar
    02-14-2016 05:11 PM
  7. Jake12121's Avatar
    02-14-2016 05:11 PM
  8. Jake12121's Avatar
    02-14-2016 05:12 PM
  9. Jake12121's Avatar
    02-14-2016 05:12 PM
  10. B. Diddy's Avatar
    The fact that Cell Standby is using 7% suggests that you might not have great cell signal throughout the day. It would help if you tap the battery graph there in order to get the fullscreen graph that also shows cell signal strength--does that show up on your phone? If the cell signal is often poor (evidenced by lots of red or yellow), then the phone has to work harder to latch onto the signal, which uses more battery.
    02-14-2016 07:44 PM
  11. Jake12121's Avatar
    I have no idea how to pull that up but my signal is often very strong. Also my screen seems to be using so much more than everyone else with this phone. I have brightness on the lowest setting. When I first got the phone everything was fine. I went days without charging no problem, now it drops so ridiculously fast it's becoming a huge issue.
    02-14-2016 11:43 PM
  12. Jake12121's Avatar
    Also Google Play services used to use 1%
    02-14-2016 11:44 PM
  13. B. Diddy's Avatar
    In the screenshot from this post, tap the graph. That should bring up the full battery graph screen, with the cell signal strength bar.
    02-16-2016 01:55 AM
  14. chezm's Avatar
    Just got this on Friday, gotta say so far the battery is on par with my S6... With doze and massive battery I was expecting much more.
    02-16-2016 10:08 AM
  1. Note 4 connectivity issues
    By Nick_1020 in forum Samsung Galaxy Note 4
    Last Post: 03-05-2016, 10:17 PM
  2. S4 Battery Drains Fast
    By Glowsticks in forum Samsung Galaxy S4
    Last Post: 02-18-2016, 01:38 AM
  3. Power / Volume Button Issue (for months now)
    By NJ LIFE-HACKER in forum Moto X (2014)
    Last Post: 02-14-2016, 10:37 PM
  4. samsung music player app issue.
    By MadMexican73 in forum Samsung Galaxy Note 5
    Last Post: 02-14-2016, 12:41 AM
  5. {Weird issues} Cannot connect to PlayStore and Apps problems
    Last Post: 02-14-2016, 12:29 AM
