1. telrod11's Avatar
    Since Moto can't seem to get a charging sound to work, are there any battery apps out there that will give me a sound when I plug / unplug?
    TIA
    10-12-2016 06:49 AM
  2. telrod11's Avatar
    Bump....
    Anyone?
    10-30-2016 12:13 PM
  3. pizza_pablo's Avatar
    TIA
    Settings > sound & notification > other sounds
    12-19-2016 07:54 PM
  4. telrod11's Avatar
    So when you plug / unplug your charger, you are getting a sound? Doesn't work on my mine or my wife's...
    12-20-2016 09:02 AM
  5. pizza_pablo's Avatar
    No. I just checked with my watch disconnected. Sorry!
    I usually have android wear silence the phone, when connected.
    I am on stock software, currently.
    I used to get charging sounds, when it was on TruPureXMM ROM.
    My apologies!
    12-20-2016 11:30 AM
  6. telrod11's Avatar
    No problem. I was hoping you had a fix!
    12-21-2016 07:23 AM
  7. pizza_pablo's Avatar
    It should just work, since it is a selectable option.
    Go figure... \_0_/
    There are a few in the Play Store, but they have minimal reviews. I was going to try one for you, since I gave you false hope, but I don't trust them enough.
    12-30-2016 02:51 PM
  1. Who will never pre order again?
    By BlackZeppelin in forum Samsung Galaxy Note 7
    Last Post: 10-14-2016, 09:33 AM
  2. Replies: 17
    Last Post: 10-13-2016, 12:29 PM
  3. Do you guys think pixel price will be drop down in 6 months ?
    By Sagar VK18 in forum Google Pixel & Pixel XL
    Last Post: 10-13-2016, 09:36 AM
  4. Replies: 1
    Last Post: 10-12-2016, 04:57 AM
  5. Phone will not power down...voice assistant is in control
    Last Post: 10-12-2016, 02:51 AM
