1. BoneDigger's Avatar
    After having the phone for a while now, my battery is lasting only about half a day. The battery information shows nothing out of the ordinary. The screen brightness is set fairly low. I'm now charging two or three times every day.
    Ideas?
    12-05-2016 10:39 AM
  2. krazyatom's Avatar
    If you can take a screenshot of your usage, it will be helpful.
    Laura Knotek and B. Diddy like this.
    12-05-2016 01:36 PM
  3. Rukbat's Avatar
    And "a while now" matters. If it's been a couple of years, it may be time for a new battery. (If you treat the battery correctly - never letting it drop to under 40% - it should last until we no longer use 4G.) If you usually drain the battery almost all the way, a month or two can kill it.
    12-05-2016 02:07 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! As krazyatom mentioned, seeing some battery stats would be helpful. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    krazyatom likes this.
    12-05-2016 03:08 PM
  5. benjamminh's Avatar
    The MXPE has only been out for fifteen months. I have it. For a few months I was getting about 12 hours on with 5 hours SOT, which was pretty decent. But a few months later I was down to 11 hours on with 3 hours SOT. I attribute that partly to the turbo charging degrading the battery faster than regular charging. The screen is a battery hog and the processor isn't terribly efficient. Otherwise I really like the phone, although it's now my backup.
    12-06-2016 10:11 AM
  6. chuckles1024's Avatar
    I've been using my MXPE since December 2015 and I use it quite a lot daily. At first the battery seemed great but after a few months it started to gobble the battery after a couple/few hours of web surfing and mostly news apps. No gaming at all. Worst thing is the battery connector started to give me trouble a couple of months ago. I bought one of those magnetic connectors and that sort of fixed that. Lately I have to charge it at least once during the day and I usually plug it in again during dinner so I have juice for late-night surfing when it will die again, signalling my bedtime
    I bought the Moto Z Play Droid yesterday even though I love everything about the Moto X except the current battery life, but it will now be my music iPod and backup phone -- or get handed down to one of my kids when she complains that the LG Optimus Zone 3 that my wife thinks she should have is too small or not good enough. And I wouldn't blame her for that.
    02-15-2017 01:06 PM
  7. Gunrack's Avatar
    Doing a restore back to factory settings did wonders for my battery life.
    acejavelin and J Dubbs like this.
    03-05-2017 12:11 PM
  8. itic's Avatar
    No kidding.. been putting that off...
    03-12-2017 08:29 PM
  9. the reel d-dave's Avatar
    I guess I hadn't noticed my battery die horrifically fast. I used to easily get a day out of it: Be 60% after the end of the day. I do have 4g and wifi connection issues, so I knew they were causing my phone some stress at it looked around. I just did a refresh two weeks ago, and this is my poor battery. I intentionally ran it down because I thought you were supposed to drain it every month or so.
    I keep my screen pretty low (30% or less), and I can't get 2 hours of Screen Time a day. My batter habits are: off charger at 5am weekdays, charge about at 40-50% (usually on the 30 minute drive home with my quick charger), then go to be about 10pm and charge it over night: usually 30-40%.
    I missed the boat, so Turbo Charging is Bad? Wouldn't that open the doors to some kind of battery replacement fiasco if they sold you the recommended charger that destroys your battery? Also, I bought my original in October 2015 and had to have a full replacement after the screen broke, my replacement didn't connected to my provider. I've had this particular phone since January 2016.
    Any wise insight is much appreciated!
    03-27-2017 08:12 AM
  10. Aj2488's Avatar
    Same problem here. I did a full restore 2 weekends ago and it didn't help the battery life at all..... I'm glad it's quick again but that's all I gained. I'll wake up and unplug the phone, walk the dogs with Spotify and Map My Walk running and after that my phone is down to 60% (within the first hour of being unplugged!!). I'll throw it on the charger as I get ready for work and by the end of the day I'm down to less than 15% and that's without watching videos or even using it very often. I've started looking at new phones but nothing really catches my eye. It's very disappointing because I love this phone in every other way.
    Attached Thumbnails Battery issues?-screenshot_20170406-022942.jpg   Battery issues?-screenshot_20170406-022950.jpg
    04-06-2017 03:29 AM
  11. itic's Avatar
    But im kind of wondering once its restored will it install the latest OS - security updates that were installed before the restore?
    Ive also read on XDA that reducing the resolution of the screen to 1080 saves the battery.
    04-06-2017 05:18 PM
  12. ffejjj's Avatar
    Booo
    05-13-2017 10:42 AM
  13. beandaddy's Avatar
    Booo
    Shoot. I don't get 4 hours total out of mine and you've got 4 hours left.
    05-18-2017 09:04 AM
  14. sybilwayne30's Avatar
    I had an issue recently where I had to factory reset my MXPE. Up until then, I hadn't been getting great battery life. I had replaced my original battery several months ago so it was better but not great. I work a 12-hour day when you include travel time and I always had to recharge by early afternoon. However, after I did the factory reset, my battery life has been exceptional. I don't know what caused it, but I am very pleased. The factory reset fixed the issue I had and fixed my battery life problem. I was very surprised.
    05-20-2017 08:21 AM
  15. beandaddy's Avatar
    I reset mine. That made it boot a bit faster.
    Took most of a week to backup/restore/configure
    I miss titanium bu.
    My wife's has the accident warranty. New one got here Friday. Her battery performance was worse - and under warranty...
    They're saying recharging at 40% now.
    This means I'd be plugging in every hour.
    05-21-2017 08:07 AM
  16. J Dubbs's Avatar
    My MXPE is a year and a half old, and the battery hasn't lost anything at all. I factory reset after the upgrade to marshmallow, and doze is working beautifully.
    My phone will last 2 days easy if I want to push it, but I top it off every night before bed, then unplug it and turn it off.
    Running the phone down low and turbo charging it all night kills the battery quick.
    05-21-2017 09:03 AM
  1. WiFi issues after nougat update
    By rcpa in forum LG G5
    Last Post: 12-08-2016, 07:35 AM
  2. Camera issue for LG Class. [HELP]
    Last Post: 12-05-2016, 03:45 PM
  3. Battery mods charging speed
    By heath patrick in forum Moto Mods
    Last Post: 12-05-2016, 03:10 PM
  4. Android System Killing Battery
    By JimK#CB in forum Moto Z & Moto Z Droid Edition
    Last Post: 12-05-2016, 02:14 PM
  5. Review: extended battery case for the S7
    By bsannes in forum Samsung Galaxy S7
    Last Post: 12-05-2016, 08:39 AM
