1. Gunrack's Avatar
    I installed Android Pay yesterday morning on my Moto X Pure and noticed that afternoon my phone getting hot and the battery rapidly discharging. The battery drained last night for the first time in a long time.
    This morning I'm seeing the same thing. Warm phone and excessive battery usage.
    I turned off NFC in the settings and the phone cooled off. Charging it now.
    Anyone know of any issues with Android Pay and NFC on their phones? First time I've installed it and was wondering if it's constantly running in the background waiting to spend some money.
    Thanks,
    Scott
    03-16-2017 01:29 PM
  2. acejavelin's Avatar
    I would do a Network Settings Reset, then a cache wipe in recovery.
    03-16-2017 11:32 PM
  3. Ry's Avatar
    Thanks,
    Scott
    I did not observe the behavior you describe on my Moto X Pure Edition.
    I leave NFC on all the time.
    Laura Knotek likes this.
    03-16-2017 11:55 PM
  4. Laura Knotek's Avatar
    Mine is on all the time too, and I haven't had those issues either.
    03-17-2017 12:52 AM
  5. J Dubbs's Avatar
    Same here, NFC on always and no effect on heat or battery at all. I've never used Android pay tho either. It sounds like an app problem... Maybe uninstall and reinstall if nothing else works?
    Android pay was so badly broken on the Nexus 6's with nougat 7.1.1 that Google is forcing an OTA downgrade to 7.0, so maybe it's glitchy on MM as well. It sounds kinda problematic 😮
    03-17-2017 07:05 AM
  6. acejavelin's Avatar
    I use Android Pay and keep NFC on all the time, I have no heating or battery drain issues.
    Try clearing your cache partition. https://motorola-global-portal.custh...p/30,6720,9541
    03-19-2017 09:34 AM
  7. Gunrack's Avatar
    It appears to have been not related to Android pay and NFC. It did this for one day and the next day it went away. After the battery seems better than ever! Go figure!
    03-21-2017 02:58 PM
  8. SmartAssBill's Avatar
    ive noticed my phone has been running hot and battery is draining alot faster. started about two weeks ago when the december update came through.
    03-22-2017 02:46 PM
  9. SmartAssBill's Avatar
    just cleared the cache so we see where this goes.
    03-22-2017 02:48 PM
  1. Android Auto and my new 2017 Impreza
    By AC Question in forum Android Auto
    Last Post: 03-22-2017, 07:05 PM
  2. Replies: 2
    Last Post: 03-17-2017, 06:15 AM
  3. why is android things showing up on my history
    By Mikewebb1978 in forum Android 6.0 Marshmallow
    Last Post: 03-16-2017, 01:44 PM
  4. why does android things show on my history
    By Mikewebb1978 in forum Ask a Question
    Last Post: 03-16-2017, 01:36 PM
  5. Battery performance?
    By mwake4goten in forum LG G6
    Last Post: 03-16-2017, 11:07 AM
