1. AC Question's Avatar
    Alright, so a few weeks ago i dropped my moto x and the screen shattered. I got all the parts, fixed it, and the screen is functioning like normal. The main problem is that the battery will drain extremely quickly, and the phone will not charge. The phone recognizes the cord as plugged in, but the battery menu says not charging. I have tried two phone chargers, both do not work. I have cleared cache, soft reset, and still nothing. The front flash is also missing, but I dont think that contributes to this problem. I was wondering if I should replace any other parts, like the charging port or the battery. In the mean time, I have been using other people's phones and using this really old tablet as a media device...........please help ;-; (also if anyone knows a adhesive that can be used to glue the screen and the frame back together please tell me)
    04-06-2017 06:52 PM
  1. Google Play won't stream on phone
    Last Post: 04-07-2017, 01:32 PM
  2. Note 4, Screensaver on locked phone
    Last Post: 04-06-2017, 05:46 PM
  3. Replies: 1
    Last Post: 04-06-2017, 05:40 PM
  4. which end of battery faces down in charger to charge battery?
    Last Post: 04-06-2017, 05:38 PM
  5. Chromebook Pin Unlock Issue
    By jmg1975 in forum Ask a Question
    Last Post: 04-06-2017, 03:48 PM
