1. psteve2005's Avatar
    I recently bought a Moto X Style and found the SIM tray didn't 'pop' out, only open slightly, so I had to prize it out with a thin piece of plastic. I also found my Samsung 32GB Evo Micro SDHC didn't work in it, however that card did work in my 2013 Moto G. As a result I returned the phone to Amazon UK on case I had a faulty unit and ordered another.
    Having received a replacement I've found the same problems, so wanted to share this with others. Does anyone else find their SIM tray near impossible to remove, and has anyone else tried this SD card in their Moto X?
    As an aside, I've just swapped from a Nexus 6P to a Moto X Style (as I missed the Moto features) and it's surprising how big the size difference is. Moto is so much smaller than the 6P and so much nicer to hold.
    11-11-2015 11:08 AM
  2. the tall guy's Avatar
    Hi, I can only really comment on the sim card tray as I don't use an SD card but it shouldn't really pop out, cause if it did you might drop it on the floor and loose it. I agree it's quite difficult to get it in and out, but once you manage to pull the tray out and put your sim in it, you probably won't be accessing that part of the phone too often.
    As for the SD card, when you put it in the phone does it just not recognize it? have you tried formatting the card?
    Laura Knotek likes this.
    12-22-2015 05:44 AM
  3. daisy's Avatar
    anyone know whether x pure and style share the same sim card tray? i got a pure its sim card tray has 2 sim card slots but the top one has been covered by plastic,wondered if that one can read sim card?
    01-21-2016 02:49 AM
  4. estooie's Avatar
    The SIM tray doesn't pop out all the way when using the SIM ejector tool. It only comes out enough for you to use your nail to slide it off.
    As for the Samsung MicroSD card... I had the same issue when formatting it to be part of the internal storage. Regardless how many times I tried, I kept getting the error that the card was too slow even though it was a Class 10.
    I replaced it with a Class 10 SanDisk, and it went through the process without any issues. So try changing your card like I did.
    01-24-2016 06:47 AM
  5. iceroyale's Avatar
    Actually, you can press the tool a little harder, and the tray will just pop right out
    02-22-2016 06:00 PM
  6. lared's Avatar
    I have a samsung evo 64 gb card and it works just fine. I have it configured as external storage.
    04-04-2016 03:05 PM
  1. Moto X problem
    Last Post: 11-24-2015, 04:51 AM
  2. Cutting down sim card...
    By hbar98 in forum Samsung Galaxy Note 5
    Last Post: 11-12-2015, 07:14 AM
  3. How do I set a screen as my home on Moto Droid Turbo 2?
    By AHNS in forum General Help and How To
    Last Post: 11-11-2015, 07:36 AM
  4. Replies: 1
    Last Post: 11-11-2015, 06:17 AM
  5. Why can't my Xperia M2 Aqua read my sim card?
    By AC Question in forum Sony Xperia M2
    Last Post: 11-11-2015, 05:00 AM
