1. Ductman1's Avatar
    Is it better to keep your phone on charge whenever possible such as driving or let the phone run down before charging ? My previous Samsung I left on charge whenever possible but with a non removable battery , not sure if staying with the same charging practice will cause an issue down the road?
    09-29-2013 10:15 AM
  2. Gekko's Avatar
    Memory effect? In a word, Nope. The phrase belongs to nickel-cadmium (NiCad or Ni-Cd) batteries. If you charge a Ni-Cd battery before itís completely discharged, it will lose capacity to charge fully the next timeÖ as if it remembers the smaller charge capacity and regards it as the new norm. Hence, Ni-Cd batteries have to be completely discharged before charging again, to retain their full lifetime between charges. This is a peculiarity of Ni-Cd batteries, not shared by Li-ions. In fact, your lithium-ion battery likes it better if you donít discharge it all the way between charges. This is why Apple recommends that you go ahead and plug in your charger when the device gives you its low battery alert. When you charge, the battery doesnít really mind if you donít top it off. Li-ion battery lifetime is all about charging cycles. One charging cycle is the time between one full charge and one full discharge. You can partially charge or discharge your battery many times during a single charging cycle. In short, your lithium battery has no memory effect, and you can recharge it, in whole or in part, whenever you feel like it. - See more at: What You Need To Know About Lithium Batteries | The Griffin Technology Blog
    09-29-2013 10:41 AM
  1. Galaxy Note 2 - Charging Problems
    By Precious Jones in forum Sprint Galaxy Note 2
    Last Post: 11-12-2013, 11:15 PM
  2. Galaxy Note 3 Battery Review
    By emiinn in forum Samsung Galaxy Note 3
    Last Post: 11-01-2013, 11:27 AM
  3. One S consuming charge when shut down
    By BuffK in forum HTC One S
    Last Post: 10-04-2013, 07:32 PM
  4. Question about Audio Settings on Nexus 7 (2013)
    By Kaesark in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-30-2013, 06:17 PM
  5. google services eating my note 3 battery!
    By cinek in forum Samsung Galaxy Note 3
    Last Post: 09-30-2013, 03:04 PM
