reversalagent
Active member
Re: Signal problems where my Galaxy Nexus had none
Before the reset, the Moto X was around -150 dBm and after the reset is around -120 to -90 dBm. Hence I can't tell for sure if this is normal or a radio issue. As I was driving home and talking, I looked back and it was green. While outside later, it was back to orangish again. I might have to pull out the Rezound and see if it was similar, even though I know they are completely different radios, manufacturers, etc.
I think it is a range of the dBm. What the values are, I do not know.
However, I do know that -60 is about as perfect as it gets, and -120 is crap.
