1. bigmac429's Avatar
    What are the best widgets on the Play Store that show time, weather and battery power? I'm coming from droids with the droid commander center widget. Was hoping for something similar to that.
    10-23-2015 02:49 PM
  2. Rocketsaucev2's Avatar
    https://forums.androidcentral.com/e?...token=PsHRDZh5
    Some decent widgets called chronus with the ability to show battery percent. Also the option of premium for a few more features but I haven't paid for it personally
    10-23-2015 03:14 PM
  3. TqSu's Avatar
    I use weather & click widget. Very clean look. Shows time, date, weather, and battery. Tapping on date opens calendar.
    Attached Thumbnails Best Widget that show time, weather and battery power-32863.jpg
    10-23-2015 05:12 PM
  4. john morris1's Avatar
    Try Transparent Weather Clock, I've been using it for years. It's great!
    10-25-2015 06:56 PM
  5. DJB628's Avatar
    Been using weather and clock widget for years and very customizable
    https://forums.androidcentral.com/e?...token=gNUABNKN.
    alphabets likes this.
    10-27-2015 07:00 AM
  6. anon(9268751)'s Avatar
    Did you mean weather and clock widget?
    10-27-2015 07:28 PM
  7. Rockler's Avatar
    New Command center 2.1.0 Droid Turbo 2 Widget was posted on XDA for both rooted and unrooted .
    Denis Runev and radgatt like this.
    10-29-2015 05:40 AM
  8. alphabets's Avatar
    https://forums.androidcentral.com/e?...token=6O3wt4IQ.
    How has the app been on battery life for the time you have been using it? I usually just use Google Now for my weather bc I'm worried about adding a weather widget and having it drain my battery. Thanks.
    10-29-2015 08:36 AM
  9. Rockler's Avatar
    Haven't really checked.
    10-29-2015 09:01 AM
  10. benjamminh's Avatar
    (New Command Center Droid Turbo 2 widget) Thanks! It even works with Nova Launcher, which surprised me.
    10-29-2015 09:05 AM
  11. Rockler's Avatar
    Just relaying what I saw on XDA.
    10-29-2015 09:14 AM
  12. TqSu's Avatar
    Sure.
    10-29-2015 06:02 PM
  13. TqSu's Avatar
    I never noticed any battery drain. You can set the frequency of weather updates.
    10-29-2015 06:04 PM
  14. 65fastback's Avatar
    using zooper
    10-29-2015 09:24 PM
  15. Denis Runev's Avatar
    Wow! Thanks! Really works just fine.
    10-30-2015 12:07 AM
  16. Laura Knotek's Avatar
    I like Beautiful Widgets Pro. https://forums.androidcentral.com/e?...token=wRqkGLRm
    Sullie714 likes this.
    10-30-2015 12:21 AM
  17. Sullie714's Avatar
    10-30-2015 02:41 AM
  18. radgatt's Avatar
    Nice find!
    10-30-2015 07:39 AM
  19. DerkWehler's Avatar
    Been using Transparent Weather and Clock for a while. But just recently, it stopped showing my battery level. I have deleted and re-created it, and the template shows it should have battery level on it, but when applied, it doesn't anymore. I don't know what changed. Any ideas?
    11-24-2018 03:03 AM
  20. sbs8331's Avatar
    The battery level was removed from the widget. The developer says that it is due to latest Android restrictions, though others (e.g. Chronus) still have it.
    12-10-2018 10:47 AM
  1. Replies: 1
    Last Post: 10-23-2015, 05:38 PM
  2. Replies: 0
    Last Post: 10-23-2015, 03:37 PM
  3. Replies: 0
    Last Post: 10-23-2015, 03:16 PM
  4. Replies: 0
    Last Post: 10-23-2015, 03:15 PM
  5. Stock Weather Widget displays as regular clock?
    By Corie Marvin in forum Samsung Galaxy S5
    Last Post: 10-23-2015, 02:51 PM
