1. phillygrl's Avatar
    After I charged my phone I went to bed, and when I got up had < 10% battery. Took a look at usage and the majority is being used by mdnsd. I do not have FireFox or Greenify installed and I've cleared the cache to see if it would go away but it did not. I have no idea how this just appeared on my phone with no way to remove. Any help appreciated, I really do not want to have to do a factory reset.
    Thanks!
    04-08-2016 09:38 AM
  2. Citizen Coyote's Avatar
    From a Google search, it looks like this problem has cropped up with multiple apps although Firefox seems to be the most recent culprit. If you've never installed Firefox and have this popping up, you could try a couple things before resorting to a factory reset:
    1. Turn the phone off, charge it to full, then turn it on.
    2. Change the accuracy of your location services (if it's on low, switch it to high and vice versa).
    3. Look through your recently installed apps; are any of them heavily reliant on an internet connection? If so, try uninstalling them and see if that helps.
    If none of this helps and the process persists through a reboot, you can always try clearing your system cache using the recovery menu. Follow the process here.
    B. Diddy likes this.
    04-08-2016 11:14 AM
  3. B. Diddy's Avatar
    See this thread as well: http://forums.androidcentral.com/and...g-battery.html
    04-08-2016 12:57 PM
  4. phillygrl's Avatar
    I've already done all that per OP except to start uninstalling apps.
    04-08-2016 02:55 PM
  5. B. Diddy's Avatar
    Any remote control apps for a drone? That also seems to be associated.
    04-08-2016 03:05 PM
  6. phillygrl's Avatar
    No I do not have Greenify installed.
    04-08-2016 03:21 PM
  7. B. Diddy's Avatar
    Greenify isn't a remote control app for drones--it's used to freeze or disable apps on the phone that you might otherwise not be able to.
    If you don't or have never played with remote control drones, then my question is irrelevant. But was just checking, because it's been mentioned before as a possible culprit.
    04-08-2016 03:46 PM
  8. phillygrl's Avatar
    Ok, no I don't just thought I read that it did.
    04-08-2016 04:10 PM
  1. Replies: 4
    Last Post: 05-28-2016, 06:26 PM
  2. Replies: 7
    Last Post: 04-08-2016, 08:47 PM
  3. Replies: 1
    Last Post: 04-08-2016, 01:16 PM
  4. Weird problem with and SD and battery drain, why is it happening?
    By AC Question in forum Hardware Hideaway
    Last Post: 04-08-2016, 09:43 AM
  5. Do I need to encrypt my phone?
    Last Post: 04-08-2016, 09:25 AM
