I'm running a non-rooted, Moto X Play with 6.0.1 Android with 32GB class 10 SanDisk SD card formatted as internal.
It worked perfectly for months after purchase. A few days ago I woke up to the SD problem, where the Phone doesn't recognize the SD Card. I haven't cliked the "forget" button since it might kill all the info I have on the SD.
After restarting the phone it works OK for several hours. It might randomly get the popup the error. I can constantly replicate it by connecting the phone to the wall-charger, the one that came with the phone. I'm restarting the phone every morning for it to work ok during the day. But on the last 2 days it popped the error randomly during the day.
I found lots of posts with the description of the error. But not a single one with a definite solution to this.
A couple of questions:
1. Is there a definite solution for it?. What is it?.
2. Is the SD card being damaged by the phone?. Or is it just a software issue?.
3. Will getting a new SD card solve the issue?.
4. If I format the next SD card as external... will I be able to runn apps (games) from there without performance issues?.
5. Might a factory reset of the phone do the trick?.
Thank you,
Thank you,
