1. Joseph Coates's Avatar
    OK, so I'm not sure if it and app, and its not terrible, but in the past few weeks the battery seems to be losing power more quickly. I used to be able to leave it at night and it would drop 10-20%, not its dropping about 40%. I'm also using 10-15% more during the day. Any suggestions? If I have to do a factory reset, how do I back up my texts? Thanks.
    11-18-2016 06:40 AM
  2. B. Diddy's Avatar
    Seeing some battery stats might be helpful. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    11-18-2016 11:04 AM
  3. 1901Madison's Avatar
    I've also noticed that my Z Force has been draining battery somewhat quickly while in my pocket. Not anything crazy, but 2-3% per hour with virtually no use. I thought this used to be more like 1%. What are your experiences with standby battery?
    As an aside, Doze is working because I lost only 3% overnight. Is it possible the Z Force just isn't that well optimized for background activity?
    11-19-2016 02:11 PM
  1. Mophie battery mod
    By masseurca in forum Moto Z Force
    Last Post: 02-06-2017, 04:38 PM
  2. Unaccounted battery drain and laggy
    By Rhyu in forum Samsung Galaxy Tab S 10.5
    Last Post: 11-18-2016, 07:09 AM
  3. How long does it take to charge a LG V20 battery fully?
    Last Post: 11-18-2016, 02:26 AM
  4. Battery drains fix
    Last Post: 11-18-2016, 12:57 AM
  5. Replies: 1
    Last Post: 11-17-2016, 08:50 PM
