1. Ry's Avatar
    For those that have the low notification issue, where it sounds like it cuts off in the beginning, due to the escalating volume feature, it appears that Motorola is working on a change that will address the issue.
    https://forums.lenovo.com/t5/Moto-Z-.../3514410#M2795
    via MattForumMngr on the Lenovo Support Forums:
    I'm happy to report that we're finalizing a software change that will address this issue and restore the notification volume to previous levels. We expect to start final testing very soon.
    I'll provide more information when I have details on delivery of the software.
    MattForumMngr also notes that this update will make it's way to all Moto Zs (Droids and Unlocked) eventually, but obviously not at the same time.
    It applies to them all but that doesn't mean they will all get the software change at the same time.
    sulla1965 and Gebo like this.
    12-19-2016 03:18 PM
  2. sulla1965's Avatar
    Thanks for the info. I was about to put my Moto Z Force up for sale. But I'll wait to for this update/fix first.
    12-19-2016 06:49 PM
  3. plumber75's Avatar
    When you say low notification issue, does that include call ringtone starting so low you can hear it?
    12-20-2016 12:27 PM
  4. Ry's Avatar
    That's escalating ringtone and as far as I know, that should work that way. If anything, Moto will update it to include a toggle.
    The issue is that escalating volume is being used for notification alerts as well. These tend to be much, much shorter than ringtones. They're not long enough to get louder.
    maxman1 and ASD Dad like this.
    12-20-2016 12:42 PM
  5. HES's Avatar
    So a toggle to turn off the escalating ringtone feature?
    12-21-2016 11:32 AM
  6. Ry's Avatar
    Escalating ringtone isn't the issue. That's working as designed. I don't know if Motorola will update the OS to include a toggle for it.
    maxman1 and HES like this.
    12-21-2016 11:58 AM
  1. Google Pixel is no Note 7
    By budven in forum Phone Wars
    Last Post: 09-13-2017, 11:59 AM
  2. Replies: 1
    Last Post: 12-19-2016, 04:03 PM
  3. Replies: 1
    Last Post: 12-19-2016, 03:07 PM
  4. How do i disable a grey circle on my screen.
    Last Post: 12-19-2016, 03:00 PM
