1. JIH2009's Avatar
    I've been noticing for the past week or so some odd battery drain overnight. I'll charge to 100%, unplug and go to bed, when I wake up I'm down about 20%. I'm noticing the phone is awake many many times and Android OS is keeping the phone awake for hours. Ill attach some screenshots. Anyone have any thoughts or ideas??
    Attached Thumbnails Strange battery drain-screenshot_20170201-085346.jpg   Strange battery drain-screenshot_20170201-085351.jpg   Strange battery drain-screenshot_20170201-085413.jpg   Strange battery drain-screenshot_20170201-085429.jpg   Strange battery drain-screenshot_20170201-085435.jpg
    02-01-2017 11:11 AM
  2. doogald's Avatar
    Plug it in overnight while you sleep so it is always fully charged when you wake up. No, it is not worse for the battery to do that.
    Your cellular signal is not great; that may be contributing to battery usage.
    See also:
    Five Smartphone Battery Myths, Explained
    What You Should (and Shouldn’t) Do to Extend Your Phone’s Battery Life | The Wirecutter
    02-01-2017 12:08 PM
  3. Tarah Sorber's Avatar
    Mine has been doing the same thing since yesterday.. nothing is draining the battery that i can see...so im not sure whats going on.
    02-02-2017 11:16 AM
  4. mobrules's Avatar
    If you don't have GSam Battery Monitor installed yet, install it and let it run.
    Charge your phone to 100% and let GSam run overnight.
    On the main GSam screen there's an icon on the bottom that looks like a vacuum. It's the app sucker screen and will show you which apps are running.
    Screenshot that and many here will offer suggestions. Hope that helps.
    02-02-2017 04:39 PM
  5. JIH2009's Avatar
    Due to my weak signal I tried airplane mode overnight with just WIFI on...same issue.
    I'll give GSam a try...
    02-02-2017 08:40 PM
  6. mobrules's Avatar
    Post some screen shots and I will try to help.
    Just curious why leave WiFi on at night?
    02-02-2017 09:03 PM
  7. doogald's Avatar
    02-02-2017 10:20 PM
  8. ASD Dad's Avatar
    Does your battery drain that rapidly during the day just sitting idle?
    I have bad cell signal at my home, worse than yours judging by the colored bars, and mine does not drain that much at all just sitting. It was asleep with no wakelocks all night according to my stats and I think I lost maybe 4-5%.
    02-03-2017 08:56 AM
  9. JIH2009's Avatar
    GSam was a bust since it doesn't work well in Nougat. It's Android OS that is keeping the phone awake between 3-4 hours at a time.
    02-03-2017 01:36 PM
  10. mobrules's Avatar
    Yeah I forgot about that........ I use several different devices.
    Here's some suggestions. Shut down 4g and WiFi at night. Under settings-data usage-turn on data saver. Calls and texts still come through.
    I also look at each app settings. Each app has a data usage setting. Inside that is an option to enable/restrict background data. You might be surprised how many apps have access to background data unrestricted.
    This is a personal preference and can be turned on/off if it causes any issues. I have 140 apps installed but only about 10-15 have access to background data.
    Have you set up developer options yet? If not do so, here's the path to turn it on. Settings-about phone-tap build number 7 times. Under developer options the 6th option down is running services. See what is actually running in the background. I would charge up and then look there after a big battery drain.
    Hope some of this helps.
    02-03-2017 05:34 PM
  11. babracmmm's Avatar
    Last night I went to bed with 100% battery. Woke up late because alarm didn't go off. Battery was dead. This has happened twice in the little over a month I've had the phone. Normally the phone will go all night and all day and still be at 40-50% when I get home from work after the previous evening charge. It says "Android system" 52% and "Voice mail" 20% for battery usage overnight. Not sure what to do about Verizon voice mail (whatever that is--an app?). I think last time this happened it was taking up a lot of battery.
    02-28-2017 08:25 AM
  12. doogald's Avatar
    1. Try restarting the phone. It may be that restarting will fix whatever is up with VVM.
    2. If you depend on your phone as an alarm in the morning, plug it in overnight. No, that is not worse for the battery.
    3. This also may help: What You Should (and Shouldn’t) Do to Extend Your Phone’s Battery Life | The Wirecutter
    4. You may try calling Verizon to report the issue with voice mail. It may be that you have a message that your phone can't retrieve, etc. Maybe their tech support can clear or reset your voice mail at their end.
    02-28-2017 10:00 AM
  13. Sandman333's Avatar
    Seems to be the same issue I'm having with my DT2 after the Android 7 update. Is your phone also getting unusually warm, even just sitting on a table and not being used? Last night my phone started that again and I shut off the BT radio. It immediately started to cool down and the battery drain quit. Android System is also always at the top of the app power use list when this abnormal battery drain happens on my phone.
    03-22-2017 07:09 AM
  14. babracmmm's Avatar
    I haven't had the problem again since I posted. But no, it wouldn't get hot. Sometimes it will get warm when I'm driving between different cell reception areas. I'm still having something conflict with the Bluetooth playback/clipping. It will be working just fine, then the phone does something and the BT starts clipping. I have to reboot the phone and it stops. Yesterday I noticed it was right after an email came in. It could be so many things, but it does seem the battery is not lasting as long after the March security update I received, even though the percentages listed under battery look normal.
    03-22-2017 10:04 AM
  15. JIH2009's Avatar
    I have solved my battery drain problem! I figured it was related to being a 5ghz wifi signal vs 2.4ghz. I switched to 2.4ghz on my home network and my battery is back to normal. Android OS is no longer keeping the phone awake for hours on end.
    doogald and jesta192 like this.
    03-27-2017 12:49 PM
  16. jesta192's Avatar
    That is interesting, to say the least! Let us know if that really solved the problem after a few days. I may try the same...
    03-27-2017 10:54 PM
  1. Replies: 3
    Last Post: 02-11-2017, 07:20 PM
  2. S7 battery life from bad to deplorable
    Last Post: 02-04-2017, 08:09 PM
  3. Post your Battery Usage
    By Steemlives in forum OnePlus 3 & 3T
    Last Post: 02-01-2017, 01:30 PM
  4. S7 battery drain
    By Kevj79 in forum Ask a Question
    Last Post: 02-01-2017, 11:11 AM
  5. mdnsd draining battery
    Last Post: 01-31-2017, 10:20 AM
