1. AG097986's Avatar
    Has anyone found a USB-C cable that also has an audio jack? I use the aux for audio in my car, but need to charge my Moto Z, as well.
    02-22-2017 12:06 PM
  2. Aquila's Avatar
    No, unfortunately that's not something that is supported by the USB spec. It might be possible to do through a USB hub.
    Laura Knotek likes this.
    02-22-2017 12:10 PM
  3. doogald's Avatar
    One idea is to try a Bluetooth adapter that you plug into the aux jack in the car.
    As recommended by thewirecutter.com, this looks good: https://www.amazon.com/dp/B0176G5TRO...cUvbUpU5687344
    Aquila likes this.
    02-22-2017 01:28 PM
  4. xeene's Avatar
    Another option is if you are using battery mod you can get a wireless charger like air dock and plug your audio jack into Usb-c while phone charges wirelessly.
    Or you can do like I do. I have a Bluetooth fm transmitter that transmits on certain radio frequency that you pick and you just set your radio to that station.
    doogald likes this.
    02-22-2017 02:04 PM
  5. doogald's Avatar
    Where I live, that is virtually impossible. All of the frequencies that these sorts of devices use are in use. At least the last time I tried this, I also found that my car antenna was either too far away from the device, of the device wasn't powerful enough, to get a good signal when I did find one. And then you pass a lot of cars tuned to the same frequencies that interrupt what you are listening to. The aux jack devices are a lot more reliable IMHO. (Though I solved this for good by installing a Kenwood BT radio with USB connection myself.)
    02-22-2017 07:31 PM
  6. jesta192's Avatar
    I drive a company vehicle and I can't swap out the stereo. So I bought this:
    http://forums.androidcentral.com/e?l...token=pkmigFZa
    You can either plug it into Aux, or it will broadcast over FM. You could also use it as a traditional wired FM transmitter. It's not perfect (what Bluetooth device is?) but it works well enough for me.
    02-23-2017 12:08 PM
  7. canonBoy's Avatar
    So for audio in the car, I use this...
    https://www.google.com/search?q=bluj...KJC10QlKsBCKMB
    I get about 8-10 hrs of playback time.
    However I would be interested in such a device you mentioned for when I'm listing to wired phones and needing to charge at my work desk.
    02-23-2017 10:38 PM
  8. kf6kmx's Avatar
    http://forums.androidcentral.com/e?l...token=E_HkUAMp
    That's the one I have in my 03 Z71... The antenna is on the far side of the truck,but this is right by the radio plugged in... Most FREQS around here are used also but this stomps all over the one I use... As long as a signal is playing it overpowers the broadcast... If the Bluetooth is a dead air you can hear a little background
    02-27-2017 05:28 PM
  1. Verizon Device Add On with UDP
    By livewiremaxx in forum Verizon
    Last Post: 03-06-2017, 12:58 PM
  2. Samsung S7 Edge SM-G9350 China Version How can change software working with Google Apps?
    By Benawitz in forum Samsung Galaxy S7 edge Rooting, ROMs, & Hacks
    Last Post: 02-23-2017, 12:39 PM
  3. Replies: 1
    Last Post: 02-22-2017, 05:19 PM
  4. How to turn on audio for ear phones
    Last Post: 02-22-2017, 10:18 AM
  5. samsung note 5 with a possessed att drive mode
    Last Post: 02-22-2017, 01:25 AM
