1. heath patrick's Avatar
    Can somebody help me figure this out. Wi-Fi is draining my battery and I'm not even using Wi-Fi. I have unlimited data with Verizon and today I left my Wi-Fi off. You can see from the screenshots Wi-Fi is draining my battery even though it's off.
    09-15-2016 10:17 PM
  2. heath patrick's Avatar
    Picture 2
    09-15-2016 10:20 PM
  3. heath patrick's Avatar
    Last one
    09-15-2016 10:20 PM
  4. tx_tuff's Avatar
    Go to settings, click on Location. At the top right of that screen click on menu button (the three dots), a window with "Scanning" will pop up. Click on that, you will go to a screen that you can turn off Wi-Fi scanning and Bluetooth scanning. Even when you have Wi-Fi turned off in your regular settings it will stay on for Wi-Fi scanning that makes your GPS faster and more accurate.
    By the way I wouldn't say that 193 mAh in almost 8 hours is draining your battery down.
    09-16-2016 12:40 AM
  5. heath patrick's Avatar
    Thanks just turned them off. Was that something new to this phone or has that been in Android for a little while. I've never noticed it before.
    09-16-2016 04:15 AM
  6. tx_tuff's Avatar
    To be honest I have no idea.
    09-16-2016 04:28 AM
  7. Revolutionary's Avatar
    Been there for a while.
    09-16-2016 08:25 AM
  8. heath patrick's Avatar
    Thanks that did it Wi-Fi is not even showing up in my usage anymore.
    tx_tuff likes this.
    09-16-2016 12:33 PM
  9. mobrules's Avatar
    I have noticed a few times after using GPS that wifi scanning will be turned back on. I had to go in and shut it back off.
    09-16-2016 03:31 PM
  1. S7 edge battery draining fast
    By hishaq96 in forum Samsung Galaxy S7 edge
    Last Post: 01-09-2017, 10:29 AM
  2. Will the replacement Note 7's in the US have this new "Green" battery icon?
    By felloffthetruck in forum Samsung Galaxy Note 7
    Last Post: 10-08-2016, 02:18 AM
  3. [Editorial] The Future of Wifi & Wireless
    By T0ASTERvan in forum Samsung Galaxy S5
    Last Post: 09-17-2016, 05:59 PM
  4. Replies: 2
    Last Post: 09-17-2016, 07:27 AM
  5. GSam Battery Monitor
    By bat1939_KM in forum Moto Z Force
    Last Post: 09-15-2016, 08:35 PM
