Hi Stéphane,
thank you for your great app "Forward My Calls".
Since your app seems to be the only working Android solution for location based call forwarding (I also tried "Smart Call Forwarding", but this did not work reliably at all), I'd like to ask you about two feature requests.
First, it would be great to be able to configure more than one WiFi-based location for forwarding, for example "Home" and "Office", in order to be able to forward calls to two different landlines depending on whether you are at home or in the office.
And second, it would be extremely useful if WiFi-dependent call forwarding could be based on the simple presence of a certain WiFi SSID. For example, there is a certain WiFi SSID at my office, but I cannot connect to it with my phone. Therefore, it would be great if Forward My Calls could be configured to forward calls based on the mere presence of a certain Wi-Fi SSID, not only based on the actual connection to a certain Wi-Fi SSID.
Do you think that it would be possible to add these two features to your app?
Thank you,
David.P
