1. NoobTube's Avatar
    My wifes Droid 2 will only enter 2 words in any text field either by virtual or physical keyboard...really strange...any ideas?
    10-07-2011 09:28 AM
  2. silverfang77's Avatar
    From the home screen. Menu>Manage Apps>All>Multitouch Keyboard>Clear data.
    10-07-2011 05:54 PM
  3. NoobTube's Avatar
    I think it worked. Thanks
    10-10-2011 01:54 PM
  4. silverfang77's Avatar
    You're welcome. Who's the hockey player in your avatar?
    Sent from my DROID2 using Tapatalk
    Coinstar11 and jt25741 like this.
    10-10-2011 02:28 PM
  5. Coinstar11's Avatar
    I've been fighting this for awhile...first form I checked, correct remedy too. Thank you Silverfang
    10-21-2011 09:39 PM
  6. jt25741's Avatar
    silverfang77, you are a life saver.....I was struggling with this for hours and hours.......so frustrating... Anyone understand how this problems occurs? Is it a random bug, or something that can be avoided?
    11-16-2011 10:06 PM
  7. DemolitionGirl's Avatar
    Worked on my coworker's phone....thanks!
    (and btw...that looks like Alexander Ovechkin in the hockey pic)
    GO KINGS GO!
    12-05-2011 03:00 PM
  8. silverfang77's Avatar
    As far as I can tell, it's a Gingerbread bug.
    @ DemolitionGirl Thanks!
    12-06-2011 11:13 AM
  9. paigemariee's Avatar
    I actually got use to it for a while... on the plus it's minimized my text messaging. I noticed the bug was happening a lot of times after pressing the space key between words... but not all the time. Thanks for the advice though!
    I created a debug log for it out of curiosity before clearing my keyboard data... this is what came out of it:
    02-08 13:48:48.310 24082 24082 W KeyCharacterMap: Can't open keycharmap file
    02-08 13:48:48.310 24082 24082 W KeyCharacterMap: Error loading keycharmap file '/system/usr/keychars/qtouch-touchscreen.kcm.bin'. hw.keyboards.65537.devname='qtouch-touchscreen'
    02-08 13:48:48.318 24082 24082 W KeyCharacterMap: Using default keymap: /system/usr/keychars/qwerty.kcm.bin
    02-08-2012 03:57 PM
