1. DooC's Avatar
    please help me unroot my droid 2 global?
    i thought i would like the root on this phone like i did on my droid charge but i dont.
    my phone is running 2.3.3 and has cwm on it and just wanna get rid of all that stuff
    02-26-2012 07:57 PM
  2. scarryman04's Avatar
    You'll have to SBF...follow the instructions in the rooting forum
    02-26-2012 08:58 PM
  3. sd_shadow's Avatar
    how did you root it?
    if you used pete root tools you can unroot same way
    how do you not like root, it only give you admin access
    doesn't do anything else, unless you use it
    02-27-2012 12:05 AM
