1. DooC's Avatar
    okay so i got the right download for my droid 2 global to sbf, and when it gets to 99% it say flash fail please help
    02-26-2012 11:14 PM
  2. sd_shadow's Avatar
    02-26-2012 11:22 PM
  3. DooC's Avatar
    what if im using windows will it still work?
    02-26-2012 11:39 PM
  4. sd_shadow's Avatar
    yes you burn it to a disc and it starts with reboot
    02-26-2012 11:59 PM
  5. DooC's Avatar
    does it really work with flash drive?
    02-27-2012 12:01 AM
  6. sd_shadow's Avatar
    haven't used it that way, but should work the same
    02-27-2012 12:07 AM
  7. DooC's Avatar
    okay but it only has 4g and wont download any and i dont have a disk to download any of stuff on so are their any other ways to do this?
    02-27-2012 12:17 AM
  8. sd_shadow's Avatar
    what does this mean, SBF is less than 256mb
    02-27-2012 11:58 AM
