1. DooC's Avatar
    okay so i bricked my droid 2 global this week and then un-bricked it last night.
    when i plugged my phone in to charge it it would say that it was an invalid battery, and this battery is the battery that came with the phone.
    so when i turn it on all it will show at the top right corner is the battery with the question mark in the middle of it.
    is their a solution to fix this?
    02-28-2012 07:07 PM
  2. sd_shadow's Avatar
    either your battery is bad, or your phone is bad
    most likely from your low battery trick you did
    buy new battery and see if phone charge works
    02-29-2012 07:42 PM
