1. MNTwinsFan's Avatar
    Hello.
    I connect the usb to my droid and iMac. However, I can't seem to transfer any music or pictures on to the SD card.
    I keep getting this message: "The disk you inserted was not readable by this computer."
    How can I get it to work with my iMac?
    Thanks,
    Jamie
    08-19-2010 12:29 AM
  2. dj_elite's Avatar
    My Macbook Pro does the same. Just hit "ignore" instead of "eject" and the drive will mount and you can drop stuff onto it without a problem.
    MNTwinsFan likes this.
    08-19-2010 12:00 PM
  3. popkurn611's Avatar
    Yea I did the same, just hit ignore and drag and drop what you want into the folders
    08-19-2010 04:57 PM
  4. thisisbenji's Avatar
    I put mine into usb debugging mode and no longer got that error, im using a late 2009 13" mac book pro.
    08-20-2010 08:26 PM
