1. thebizz's Avatar
    well the wait has been aginizing but matt4542 has just posted epic 1.0 for the d2 here is the thread
    going to give it a try
    edit almost forgot the link
    http://www.droidforums.net/forum/dro...hed-1-0-a.html
    09-04-2010 10:00 PM
  2. Bushido Brown's Avatar
    I think I''ll wait on the 2nd, possibly 3rd release of this. I don't have the patience to fight through potential bugs without Nandroid to fall back on
    09-05-2010 04:38 AM
  3. thebizz's Avatar
    with clockwork you can make backups. the second release has been posted fully deodexed system etc
    09-05-2010 08:46 PM
  4. phillyphreak's Avatar
    Im gonna root my d2 today. Is it fairly easy to dump extra apps? Is this rom like a bb" leaked" os? Don't mean to hijack this thread but im new to android but coming from bb im used to hacking a smartphone. Once I get the basics I'll be helping others as I can.
    09-06-2010 09:30 AM
  5. thebizz's Avatar
    yes its very easy to dump the extra apps you just want to make sure you keep them backed up somewhere or updates etc tend to fail. yes and no this is a custom rom built of the official release it has been deodexed, which means removing all the odex files so it can be themed and parts from other phones can be pushed in, some vzw apps have been removed. but its in the vary early stages the backlight stays on when you lock your phone and a few more bugs, ive talked to the dev and hes trying to fix them just trying to save his droid 2 right now
    and on a side note if you have the sbf files for the droid2 just use sbf flash in linux rsd light 4.7 doesnt like our phones very much and things tend to fail
    09-06-2010 09:45 AM
  6. kingzee's Avatar
    Too many bugs and issues with it for my taste. Plus, it seems like he did it in a hurry. Why not take your time so that it can be released right? I'm not certain, but it appears he just wanted to be first. I do believe he did a great thing, but definitely take your time and release it right.
    09-06-2010 01:50 PM
  7. Bushido Brown's Avatar
    The more people who have the rom, the faster bugs can be identified and zapped. He could sit on the rom for weeks, but eventually someone will find something wrong with it
    09-06-2010 02:36 PM
  8. kingzee's Avatar
    I understand that, but from the tone of his post, it was rushed. I'm all for providing feedback, but not on something that seemed rushed.
    09-06-2010 08:56 PM
  9. thebizz's Avatar
    09-06-2010 09:42 PM
