1. CoffeeBreak's Avatar
    I've got a battery only charger from verizon...the only one on the site that is compatible with droids. Has anyone confirmed that you can charge the bp7x extended battery with this battery only dock? I don't want to try it and ruin my battery.
    02-16-2011 11:18 PM
  2. ishore99's Avatar
    yes, it has 2 sides. Check to make sure you use the side that says "BP"
    02-17-2011 09:22 PM
  3. CoffeeBreak's Avatar
    Nice, tx. I knew that u match the models, just wasnt sure if it charged every bp etc.
    02-17-2011 11:31 PM
