1. kmr296's Avatar
    I think I am royally screwed. I'm sitting here trying in install the adroid market on my fiances nook color. I COMPLETELY FORGOT my Droid 2 was charging on a USB port. I opened up a cmd prompt as indicated here:
    http://forum.androidcentral.com/barn...r-sd-card.html
    to install the market. So basically i ran: adb shell mount -o remount,rw /dev/block/mmcblk1p2 /system with my da*# droid plugged in. Did I just complete brick my phone!??
    04-08-2011 03:25 PM
  2. kmr296's Avatar
    **Note - the battery was dead so i thought it shut off. It's def off - but will not turn on.
    04-08-2011 03:26 PM
  3. kmr296's Avatar
    **Will a hard reset do the trick?
    04-08-2011 03:30 PM
  4. kmr296's Avatar
    Won't even hard reset... yea i'm screwed
    04-08-2011 03:37 PM
  5. corydunbar's Avatar
    I doubt it, most likely an SBF is needed or you're gonna need some more serious help.
    04-08-2011 03:54 PM
