I recorded a voice ringtone for a specific contact. Turns out it is not loud enough and I want to change it. So I go into settings --> sounds and select a ringtone from the Droid default set. But it does not reset!! I deleted the app that I used to record the ringtone and re-booted but to no avail. How can I reset this contact ringtone?
- gerry
- gerry
