1. Wh0_Am_i's Avatar
    I need help because I bricked my phone and can only get to recovery mode.Im new at this so please be simple as can be.
    06-20-2013 09:13 AM
  2. sd_shadow's Avatar
    if you can't get to ap fastboot, don't think you can fix
    should be a few, ways to get to ap fast boot
    Sent from my XT862 using Tapatalk 2
    06-22-2013 11:37 PM
  3. newraze5115's Avatar
    How do I flash an xml file without using rsd and my phone is stuck in ap fastboot but rsd won't pick up my phone for some reason.
    06-27-2015 11:22 PM
  4. sd_shadow's Avatar
    Please post complete text on AP Fastboot screen.
    Sent from my XT907 using Tapatalk
    06-27-2015 11:24 PM
  5. newraze5115's Avatar
    What xml file do I flash using RSD Lite and how to do it without flash failer?-2015-06-29_15-01-20_280.jpg
    This is an pic of my fastboot screen
    06-29-2015 07:52 PM
  6. sd_shadow's Avatar
    That's not a droid 4.
    What model number is on the back cover?
    should be something like XT910, XT1097...
    06-29-2015 07:55 PM
  7. sd_shadow's Avatar
    XT1254?
    06-29-2015 07:56 PM
  8. sd_shadow's Avatar
    Motorola Droid Turbo XT1254 ?
    Verizon?
    06-29-2015 07:57 PM
  9. sd_shadow's Avatar
    What xml file do I flash using RSD Lite and how to do it without flash failer?-xt1254.png
    Battery is good, for now
    usb status should change when connected to PC,
    If you have a Motorola Droid Turbo XT1254, you need to ask here Motorola Droid Turbo
    06-29-2015 08:06 PM
  1. Selling phoness on here. Is it easy and how to do it.
    By TheyStoleMyName in forum General Help and How To
    Last Post: 06-07-2013, 08:27 PM
  2. Got used incredible from someone...how to make it back to normal?
    By jester0110 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 11-28-2012, 08:00 PM
  3. What is MD5 and how to use it to verify your download
    By LeslieAnn in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 05-08-2012, 08:03 AM
  4. What is tv out and how to use your phone through your tv
    By Dmarco79 in forum T-Mobile myTouch 4G Slide
    Last Post: 08-28-2011, 02:13 PM
  5. Replies: 0
    Last Post: 08-25-2010, 04:19 PM
