1. Mustachio's Avatar
    In Settings > More... > Mobile Networks are these settings:
    Network Mode
    Access Point Names
    Do the selections in these two settings play any role in battery life? My wife's D4 drains the battery fast but she doesn't use it much. The phone spends most of its time with her at her work, inside a large grade school. You know the kind, built quite recently (modern construction standards), with cinder blocks making up the majority of the walls.
    Of course, her cell reception there is extremely POOR. I took my Galaxy Note II there and had similarly horrible reception.
    My thought is that the battery might be draining because the D4's radio is spending a lot of juice trying to locate a strong signal (a futile effort). Would changing those two Mobile Networks settings improve the battery life?
    Ideas?
    TIA.
    09-12-2013 10:20 PM
  2. Eclipse2K's Avatar
    One of the first things I do when I get a phone is switch the network mode from Global to LTE/CDMA. Not sure about its battery effects but some people have stated if helps before.
    09-12-2013 11:17 PM
  1. Back cover for G2
    By Xtremeyouth1 in forum LG G2
    Last Post: 10-05-2013, 09:08 PM
  2. Replies: 13
    Last Post: 09-18-2013, 10:53 AM
  3. Up for the Upgrade
    By Jsteere212 in forum Sprint HTC One
    Last Post: 09-13-2013, 04:37 PM
  4. Replies: 2
    Last Post: 09-13-2013, 04:58 AM
  5. Replies: 2
    Last Post: 09-13-2013, 01:57 AM
