1. Killernick99's Avatar
    So i have had this phone for i think a year now...i love it great phone besides being slow from time to time...Also a massive tank...ive dropped it so many times but no screen crack or major chips in the frame...ANYWAYS...randomly one day i slide out my keyboard to send a text message when all the sudden it did a keypress on the messages...so i closed it reopened and repeat...same thing... So i rebooted my phone and it fixed the problem...*not really* after awhile it happen again, so i went and turned on the dev tools so allow me to see keypresses and it showed every time i slide it out it does 3 keypress in a spot.
    Overall my problem is the keypress only show up when the keyboard is slide out but not in, allowing me to use the phone but with the keyboard. But the keyboard itself still works. The only thing i havint tried yet is factory reset...figured i get some advice before i went that far...any ideas??
    09-24-2013 06:14 PM
  2. Paul627g's Avatar
    This sounds more hardware related than software... I'm guessing its showing possible signs of wear causing this issue or problem related to the drops and bumps its taken...
    You could try a factory reset but I'm really thinking this isn't so much software related.
    09-24-2013 08:40 PM
  3. Eclipse2K's Avatar
    Definitely hardware related. I had something similar happen with my Droid 2 and for me it was the keyboard membrane coming loose.
    Sent from my Motorola Droid Maxx using Tapatalk 4
    10-08-2013 08:52 AM
  1. Hi I'm running an AT&T Sim in my Verizon S3 :)
    By laurieberry in forum Verizon Galaxy S III
    Last Post: 09-27-2013, 01:14 AM
  2. Will rooting take away my camera quality
    By 92turbo2 in forum HTC EVO 4G LTE
    Last Post: 09-25-2013, 06:33 PM
  3. Full Hands On & First Look with Samsung Galaxy Note 3
    By snsn in forum Samsung Galaxy Note 3
    Last Post: 09-24-2013, 07:35 PM
  4. Possible issue with Android Device Manager and the new Lock feature
    By kremus in forum General Help and How To
    Last Post: 09-24-2013, 06:47 PM
  5. Replies: 1
    Last Post: 09-24-2013, 04:24 PM
