1. Swordsman969's Avatar
    As with everyone else I recently got the Marshmallow update. Supposedly this was supposed to help be able to transfer more apps and images over to the SD card. I've been looking at the various options, but can't figure out how to set up the SD card (I have a 32GB card) as the primary storage for the phone, including for pictures I take. I'd like to move most of my apps over the the SD card, but many of them won't do it (I assume this is a problem of the app developers and not Verizon or Motorola). Anyone have tips on how to do this?
    05-18-2016 10:26 PM
  2. Rukbat's Avatar
    More apps/fewer images.
    If the card is adoptive storage (that was your choice when you set it up), the phone decides where, physically, to put apps. Logically it's just "storage". (You shouldn't be using adoptive storage unless your phone is 8GB internal storage or less.)
    If it's portable storage, (almost all phones today should be set this way) you can "move" the same apps you could before - and a developer who knows that his phone won't run from the SD card will turn off that option. If's no good moving an app to the card if it won't run.
    05-18-2016 11:09 PM
  3. badcat's Avatar
    I just updated my Maxx 2 as well. Go to Settings>Storage & USB>Portable Storage>Touch the Cards Name. Now you should be at an Explorer type screen showing directories. Touch the three dots in the upper right hand corner and select settings. Mine has three options Eject, Format or Format as Internal. I think you're looking for Format as Internal. Obviously you need to back up your card prior to performing the format.
    05-19-2016 06:26 AM
  1. Massive data increase after system update
    By pippanelson in forum Motorola Droid Turbo
    Last Post: 05-21-2016, 01:08 AM
  2. Father needs a bit of help
    By azcolor in forum Ask a Question
    Last Post: 05-19-2016, 07:22 AM
  3. how do i increase the amount of storage on my Galaxy S4
    Last Post: 05-18-2016, 11:17 PM
  4. T-Mobile S6 Edge after the Marshmallow Update
    By GWaLL13 in forum Samsung Galaxy S6 edge
    Last Post: 05-18-2016, 11:10 PM
  5. galaxy sIII stopped receiving or sending mms with text
    Last Post: 05-18-2016, 09:53 PM
